Dana Axle Info - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 5th, 2005, 11:14 AM   #1
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Default Dana Axle Info
This is not a complete list. If anybody has anything they would like to see added to this body of info (pics, applications, etc.) please PM me and I'll update the post.
Where to get part number on the axle:
Sorry for the crappy pic, but reading the arrows from left to right:
-ratio tag
-limited slip lubrication tag
-model number
-date
-Bill of Material
Where to find the application/build info:
Dana BoM Search Page
Dana 28 TTB
Donor Vehicles:BRONCO II FRONT 83-90, RANGER FRONT 83-90 ,93 & UP
Applications: Front
Axle Shaft Diameter: 1.0 Inches
Spline count: 23
Ring Gear Diameter: 6.625 Inch
Maximum tire size for stock axle: 31-inch
Strong Points: Light weight making it good for mud. Can easily be made to produce very good articulation with only the addition of longer radius arms and custom coils.
Weak Points: Outer axle shafts break. Radius arm bushings- especially passenger side frequently need replacing due to being too close to the catalytic converters. Brakes have a tendency to warp and/or crack the front rotors. Steering the stock steering set-up is very poor for a lifted truck. Severe bump steer is usually the result, in the higher lifts (4" and up)
More Info
Dana 30
Donor Vehicles:AEROSTAR 86-90, BRONCO & U100 67-71, IHC SCOUT F 67-74, JEEP C101 F&R 67-74, CJ5&CJ7 F 67-68, JEEP J10 F 66-88, WAGON.F 67-88, CHEROKEE 86-95, WRANGLER 87-06
Application: Front
Axle shaft diameter: 1.16 Inch
Spline count: 27
Ring gear diameter: 7.2 Inch
Maximum tire size for stock axles: 31-inch
Weak points: .......
More Info
Dana 35
Donor Vehicles:CHEROKEE REAR 84-97, COMANCHE REAR 86-92, WRANGLER REAR 84-97, WAGONEER REAR 84-97
Application: Rear
Type: Semi-floating
Spline count: 27
Ring gear diameter: 7.56 Inch
Maximum tire size for stock axles: 33-inch
More Info
Dana 35 TTB
Applications: Front
Axle Shaft Diameter: 1.16 Inches
Spline count: 27
Ring Gear Diameter: 7.56 Inch
Maximum tire size for stock axle: 33-inch
Strong Points: Same knuckles and u-joints as Dana 44. 7.5" R&P are very strong. Have heard of virtually no failures. Can easily be lifted. Can easily be made to produce very good articulation with only the addition of longer radius arms and custom coils. Good aftermarket support, with many companies making lifts of all different sizes. Actually has hubs. Entire assembly is very strong
Weak points: Wheel bearings- though large, are placed too close together. Automatic hubs- prone to grenading, or giving up when you need them most. Also, only very coarse adjustment available for wheel bearings. Radius arm bushings- especially passenger side frequently need replacing due to being too close to the catalytic converters. Brakes have a tendency to warp and/or crack the front rotors. Steering the stock steering set-up is very poor for a lifted truck. Severe bump steer is usually the result, in the higher lifts (4" and up)
More Info
Dana 44 and TTB
Donor Vehicles:K10,25,30,35,F 60-80, C10 REAR 60-70, W100-350 F 69-96, F100,150 4X4 R 67-78, F150,F250 F 75-90, F100,F150 F 78-90, IHC SCOUT 74-80, 86 CJ7 Rear
Applications: Front and rear
Type: Mainly semi-floating, although there were some very rare full-floating units
Axle Shaft Diameter: 1.30 Inches
Spline count: 30 (after '72; prior to '72, some were 19-spline)
Ring Gear Diameter: 8.5 Inch
Factory ratios: 2.76:1 through 5.89:1
Maximum tire size for stock axle: 35-inch
Weight (solid axle): 240 Pounds
Strong point: Wide availability and significant aftermarket support in parts and upgrades
Weak point: Carrier and spider gears, U-joints, ring-and-pinion
Junkyard jewel: Find a front axle out of an early '80s Dodge 3/4-ton because they were equipped with locking hubs. Also, a front axle out of a '76-or-earlier ½- or ¾-ton Chevy has steering knuckles that are cast flat and easily adaptable to crossover steering
Building secrets: Upgrade the stock carrier and spider gears because they're notoriously weak. Also, if you've indexed the axle to improve pinion angle, use a diff cover from a '78 or '79 Ford ¾-ton high-pinion '44 because it allows for a larger quantity of lube and a higher fill point
Aftermarket alternatives: Currie Enterprises, Custom Differentials, DTS Custom Service, Dynatrac
Notes: They came in both low-pinion and high-pinion models, and the centersection was even used in '80-and-up Ford Twin-Traction-Beam applications. They were offered in 5-, 6-, or 8-lug bolt patterns.
More Info
Dana 50 TTB
Donor Vehicles:F250 & F350 FRONT 78-97
Applications: Front
Axle shaft diameter: 1.31 Inch
Spline count: 30
Ring gear diameter: 9.25 Inches
Maximum tire size for stock axles: 36-Inch
More Info
Dana 60
Donor Vehicles:K30,35 F 77-91, W200 250 F&R 69-93, W300 350 F 75-93, F100 R 67-85, F250 F&R 67-88
Type: Semi- and full-floating
Spline count: 16, 23, 30, 32 and 35
Factory ratios: 3.54:1 through 7.17:1
Maximum tire size for stock axle: 38.5-inch
Weight: 505 Pounds
Strong point: Available in a variety of widths, most of which were full-floaters
Weak point: The driver-side carrier bearing was known to spin on the carrier and this often spun the race, which can damage the housing
Junkyard jewel: A heavy-duty front '60 can be found on '78 and '79 ¾-ton Ford pickups equipped with the snowplow package. Some late '70s and early '80s Dodge trucks had 35-spline '60 rear axles. Rear '60s are easy to find
Building secrets: The spider-gear roll pin is small and hollow, and is prone to breakage. Builders often double up the roll pin for extra strength (slide one inside of another). Also, replace the pinion yoke with a 1350-series yoke for extra strength. Finally, be careful about the spline count. Look for the 32- and 35-spline axles, avoid the 16s and 23s
Aftermarket alternatives: Currie Enterprises, DTS Custom Service, Dynatrac, Custom Differentials
Notes: The venerable '60 has been available in either high- or low-pinion designs and was never used in an IFS application. Custom Differentials warns to steer clear of the rare but virtually identical Dana 61 because most of the parts are not interchangeable
More Info
Dana 70
Donor Vehicles:...
Type: Most full-floating with some rare semi-floating in commercial applications
Spline count: 23, 32 or 35
Maximum tire size for stock axle: 44-inch
Strong point: Large teeth on ring-and-pinion
Weak point: Small diameter pinion shaft (same as found on Dana 60)
Junkyard jewel: Rarely seen but known to exist are open-knuckle front axles with disc brakes. A rear heavy-duty '70 was fitted under '73-'91 Chevy dualie pickups, and it has larger-than-normal carrier bearings
Building secrets: When rebuilding, make sure that any stock oil-restricting device is left in the pinion area. This keeps lube in the pinion-bearing area at a higher level and retains it longer. Custom Differentials says that a number of '70s come to them with the oil-restricting devices removed
Aftermarket alternatives: Dynatrac, Custom Differentials
Notes: One of the benefits to a '70 is that there are a number of different pinion yoke sizes available, including a 1410-series yoke. Be careful though, because different housing castings used different sizes of pinion bearings due to different sizes of pinion bores
More Info
Old November 5th, 2005, 11:56 AM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
That's a sweet tech write-up.
Old November 5th, 2005, 10:02 PM   #3
nosilla
Awesome write up.
nosilla is offline   Reply With Quote
Old November 26th, 2005, 02:00 PM   #4
PavementPounder
PavementPounder's Avatar
D60 left, my D70 on the right.
Old January 12th, 2006, 09:13 PM   #5
JeepGenocide
JeepGenocide's Avatar
Default nice
that chart and diagram really explained a lot to me
JeepGenocide is offline   Reply With Quote
Old February 28th, 2006, 07:28 PM   #6
Gunsworth
Gunsworth's Avatar
Originally Posted by PavementPounder
My D70 next to a D60.
lol, wtf
/greatlakes/vbpgimage.php?do=full&p=82 Bill spilled sparks on the image server www.clarkstoncracker.com Your IP: has been logged
Old March 5th, 2006, 01:09 AM   #7
PavementPounder
Originally Posted by Gunsworth
lol, wtf
I just noticed that. I deleted the pic out of my gallery.
EDIT: Fixed.
Old March 19th, 2006, 06:15 PM   #8
jeeptrick034
Default Helpful indeed
So, i was just about to write up a question about axles...then i saw this and i no longer need to ask...good job. thanks
jeeptrick034 is offline   Reply With Quote
Old February 22nd, 2007, 09:47 PM   #9
PotatoC
PotatoC's Avatar
Send a message via AIM to PotatoC
thanx
PotatoC is offline   Reply With Quote
Old March 2nd, 2007, 11:57 AM   #10
97xj
97xj's Avatar
I just found this link to the Dana Tech Library.... Lots of good stuff
http://www2.dana.com/expert/wc.dll?cvsp~Depdf~5~AXL~
The home page is here and you can search for heavy axles, Trans, driveshafts etc....
expoded views, part numbers almost any Dana Info You might need going back to 1967.
Here just a sample. They have Dodge, Ford and GM applications listed also
Have a BOM and want to know what vehicle ?
http://www2.dana.com/pdf/X510-9-1-BM.PDF
Have a vehicle and want to know what BOM.
All applications '67-'78
http://www2.dana.com/pdf/X510-8.PDF
miscellaneous applications '79-'84
http://www2.dana.com/pdf/X510-7.PDF
Jeep Applications 78-98
http://www2.dana.com/pdf/X510-9-5-JEEP-A.PDF
Dodge Applications
http://www2.dana.com/pdf/X510-9-2-DODGE-A.PDF
Ford Applications
http://www2.dana.com/pdf/X510-9-3-FORD-A.PDF
GM Appliations
http://www2.dana.com/pdf/X510-9-4-GM-A.PDF
97xj is offline   Reply With Quote
Old November 26th, 2007, 07:56 AM   #11
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Originally Posted by 97xj View Post
"The page cannot be found"
Old January 8th, 2009, 10:41 PM   #12
muddy maki
Its tough out there.
muddy maki's Avatar
Send a message via AIM to muddy maki
i noticed too. got to nosing around on thier sites and found the service manuals
http://www2.dana.com/expertforms/depdf.aspx?prod=WAXL
muddy maki is offline   Reply With Quote
Old March 24th, 2009, 11:52 AM   #13
CreativeFab
used to be Ironman
CreativeFab's Avatar
As a side note to this tech, do not confuse a Dana 61 for a 60. Easy to do as they are identical from all outward appearences. The difference is the pinion offset in the 61 is off by .25 - .375 or so.
These axles came with either 3.07 or 3.54 ratios and making one work is more expense than it is worth. Some folks have done it with spacers and used the open carriers with welding them up or using a lunchbox for the regular 60.
The 61 was available for either front or rear applications. Pirate4x4 does have a few articles about it and what people have done to overcome their dilema of pruchasing one of these bastard axles.
These will have a BOM # starting with 610
Old April 1st, 2009, 10:34 AM   #14
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
That's not completely true. The Dana 61 can use either a Dana 60 or a Dana 61 gear set. This is not to say that they are interchangeable, but rather some Dana 61's used a Dana 60 gear set, which could not be replaced with a Dana 61 gear set, and vice versa.
Old April 1st, 2009, 01:10 PM   #15
CreativeFab
used to be Ironman
This is true up to a 4.56 according to Eaton, after that the carrier will not accept the 60 gear set.
Old April 3rd, 2009, 01:23 PM   #16
Jeeperz Creeperz
GL 4x4 Vendors
I guess my point was more along the lines of don't even bother with the Dana 61 Even with the oddball high offset D61 case and D60 gears the highest I've seen is 4.10.
Old February 7th, 2010, 06:53 AM   #17
project98
great information for a newbie looking for options to build on.
Thanks
project98 is offline   Reply With Quote
Old February 27th, 2010, 07:04 PM   #18
95Bronco
Are all 6 bolt Dana 44 spindles the same?
95Bronco is offline   Reply With Quote
Old February 27th, 2010, 09:37 PM   #19
PavementPounder
No, there are small-bearing and big-bearing.
Old August 19th, 2011, 12:15 AM   #20
crazygrady127
crazygrady127's Avatar
Very niceley done !! Answered allot of questions I was wondering about !! Thanks !!
Tear It Up - Fix It - And Do It Again
crazygrady127 is offline   Reply With Quote
Page generated in 0.60518 seconds with 83 queries
