Ford axel question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 22nd, 2007, 02:54 PM   #1
TurboChris
TurboChris's Avatar
Default Ford axel question
78-79 bronco. would anyone have a idea what axels it would have? the guy who offered it to me isnt sure isnt sure.
TurboChris is offline   Reply With Quote
Old August 22nd, 2007, 03:03 PM   #2
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Ford 9 inch (back) Dana 44 (front)
Old August 22nd, 2007, 03:06 PM   #3
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
x2...but another question is what tranfer case is most common with them...
bigjay is offline   Reply With Quote
Old August 22nd, 2007, 03:11 PM   #4
FORD FLARESIDE
I don't know the number, but it is a Borge/Warner, and its heavier then ^%$&&&%!!!!
Old August 22nd, 2007, 03:15 PM   #5
bigjay
bigjay's Avatar
lol..nice..guess ill have to crawl under it..dad told me it was a gear to gear
Old August 22nd, 2007, 03:19 PM   #6
FORD FLARESIDE
It is, and it is sought after by a lot of mud runners, because it is fairly strong.
Old August 22nd, 2007, 03:28 PM   #7
bigjay
bigjay's Avatar
good itll give me one less thing to worry about..lol
Old August 22nd, 2007, 03:35 PM   #8
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Either a np203 (chain) or np205 (gear)
If it has lock outs it is a 205, if it has drive flanges than 203
Old August 22nd, 2007, 03:47 PM   #9
bigjay
bigjay's Avatar
it's got lockouts..bu i didnt know trucks that old came with flanges..
Old August 22nd, 2007, 06:55 PM   #10
TurboChris
TurboChris's Avatar
Well I guess that my other question is - I want to put the axels under my 91 wrangler and is it necessary to use the t-case too?
Old August 22nd, 2007, 08:42 PM   #11
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
look at 99grandtj's post....ford didn't start using the B/W stuff until the early 80's. All New Process in the 78-79 full size. and the np203 and np205 where equally common from what I've ran into.
Old August 22nd, 2007, 08:43 PM   #12
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
a 203 could have hubs also....many people converted over to lockouts from the flanges.
Old August 22nd, 2007, 09:09 PM   #13
Jeepaholic
Jeepaholic's Avatar
I know it was done but that meant you had to put in a part time kit or run it in 4 hi lock all the time
Just a good rule of
Old August 22nd, 2007, 09:11 PM   #14
Jeepaholic
Jeepaholic's Avatar
No you don't as the wrangler uses the same side drop (driver side pumpkin)
Old August 22nd, 2007, 09:41 PM   #15
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Just a good rule of
I don't know anyone that used the part time kit. I've seen them advertised years ago. But I did know many guys running just lockouts.
Old August 22nd, 2007, 09:47 PM   #16
That's just cuz your a young punk kid.
Full time 4 wheel drive was common in the late 70's & with the gas crunch, many people switched to part time conversions for the economy. My dad did it on at least 2 different Suburbans.
Old August 22nd, 2007, 10:09 PM   #17
Whereas Road-house did it IN at least 2 different Suburbans. Thats why he has so many kiddies(and he likes suburbans...)
Old August 23rd, 2007, 08:09 AM   #18
PavementPounder
PavementPounder's Avatar
Yes. The front axle will have the less desireable cast ends.
As Adam said, it is not. However, the thing you need to consider is that you want to put this stuff in a YJ. My opinion is that you should skip the 1/2-ton stuff since you would be changing bolt-patterns anyway (unless you already bought wheels) and target a 78-79 F-250 HPD44/D60 and I'll tell you why:
  • 78-79 F-250's & F-350's are leaf sprung and share the same perch spacing as YJ. Broncos have a different suspension system.
  • 78-79 F-250's & F-350's are SOA from the factory.
  • The 78-79 F-250 HPD44 is the beefiest stock D44 you can get. Comes with dual-piston calipers, flat-top knuckles, 3" tubes w/0.5" wall thickness, and lockouts. Axle ratio is commonly 4.10 as well. You won't have to worry about the D60 rear until you have enough power to break it.
  • They will bolt right into your YJ SOA. The 78-79 F-350 HPD60 is configured the same way. Once you set up the HPD44, no changes are required to swap in the D60 if you ever want to upgrade.
If you want a good reference point for this axle set, see Leanz's Rig Build. She started out on her YJ with the HPD44/D60 and now has the HPD60/D60.
If you would rather stick with 1/2-ton axles, you would want a 77-down HPD44 to avoid the cast ends. Read up on the first two links here: http://77cj.littlekeylime.com/web_rs44.html
Old August 23rd, 2007, 10:18 AM   #19
TurboChris
TurboChris's Avatar
Good looking out pavement pounder. eah I knew that F250s have the same set up as a yj but didnt know 350s do. And I didnt know that Broncos were a differnt suspension set up . If any one knows of someone getting ride of a junk f250 or 350 pm me
Old August 23rd, 2007, 11:06 AM   #20
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Nope my old beater suburban had a np208 case...the wifes Burby has the piece of crap nvg243 I believe it is..the autotrac tcase.
altho' we did convert my buddys '78 burby to lockouts and he kept the 203 tcase.
Page generated in 0.49526 seconds with 83 queries
