How do these compare in strength .... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 22nd, 2007, 02:28 PM   #1
matt3liv
matt3liv's Avatar
Default How do these compare in strength ....
Chevy Corporate ten bolt, most likely the 8.25" ring, to an early bronco Dana 44
and
Chevy 14 bolt, either the 9.5 or the 10.5, compared to a Ford 9" 28 spline?
I have no idea what the spline counts are on the others.
I'm thinking about swapping from the ford axles to the chevy. What do you think?
matt3liv is offline   Reply With Quote
Old August 22nd, 2007, 03:10 PM   #2
Chevy 10 bolt is basically identical to dana 44s, both are 8.5" ring gears, 1.31" 30 spline shafts generally.
A 10.5" GM 14 bolt is a monster. Every piece is stronger than that 9" in stock shape. The 9" can be built very strong, though. You might need different bearing ends out by the wheels, though.
Page generated in 0.22192 seconds with 29 queries
