2003 5.7 Hemi - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 21st, 2007, 11:10 AM   #1
itselliott
itselliott's Avatar
Default 2003 5.7 Hemi
Well, I just got with the valve spring failure disease that seems to plague the Hemi engines . mine has 44k on it.
Getting a new short block and 1(yes 1) head under the 7/70 warranty.
1) has anyone had a similar spring failure, resulting in valve pieces trashing the cylinder etc.?
2)has dodge come up with a RELIABLE solution to the failing "beehive" shaped springs?
3) what are your thoughts on only 1 replacement head (more than likely re-manufactured and therefor milled flat -.005 to -.020"?
The dealer tells me that Hemi heads cannot be milled down, first head I've ever heard of like this(I think he's full of it). And that the compression difference side to side won't happen!!
What are your thoughts on that??
I'm suddenly feeling like my life long love affair with Mopar may be on the rocks!
Old August 21st, 2007, 12:27 PM   #2
rockrat
rockrat's Avatar
I just hit 87K on mine, no problems yet except trying to change out spark plugs; wish I'd looked into that before getting a hemi. As for milling; that sounds like a blow-off to me.
rockrat is offline   Reply With Quote
Old August 21st, 2007, 06:05 PM   #3
socketman
socketman's Avatar
I have heard that the 6.1 head (come bare) can be built and fit the 5.7 for less than you can get the 5.7 heads for complete.
socketman is offline   Reply With Quote
Old August 21st, 2007, 07:54 PM   #4
backdraft
AKA Patrick just because
backdraft's Avatar
this might get more responses in the dodge section
backdraft is offline   Reply With Quote
Old August 21st, 2007, 08:07 PM   #5
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
My bad.
I was moving it from General, and must have slipped. :tonka:
Old August 22nd, 2007, 09:39 AM   #6
itselliott
itselliott's Avatar
Is there a benefit to doing this? other than $ saving?
Old August 22nd, 2007, 06:11 PM   #7
dline
dline's Avatar
there isn't enough meat on the bottom of the head, to machine it down.
i got 2 complete spare cylinder heads, with aftermarket valve springs, pushrods, and spring retainers.
dline is online now   Reply With Quote
Old August 22nd, 2007, 10:24 PM   #8
itselliott
itselliott's Avatar
So your saying that the dealer isn't blowing smoke with that statement.............?
What can you tell me about the springs? Are the replacements going to fail in short order too?
Old August 23rd, 2007, 05:43 AM   #9
dline
dline's Avatar
no replacement springs won't fail like the oems
Old August 23rd, 2007, 10:20 AM   #10
itselliott
itselliott's Avatar
By replacement, I was thinking the replacement (3rd generation, I hear) that the dealer will use......................
Old August 23rd, 2007, 11:20 AM   #11
dline
dline's Avatar
idk on the replacements, i have aftermarket stuff on my truck @ 6600 rpms
Old August 29th, 2007, 06:40 AM   #12
itselliott
itselliott's Avatar
Well, after all the , I pick it up today.
It has a NEW ENGINE because of a failed valve spring! I'm thinking that is a lot of colatteral damage.
we'll see ...............cost,=$100 (7-70 warranty) I'm beyond 3-36.
Kind of like waiting your girl to unwrap her bewb job.........
Page generated in 0.44973 seconds with 59 queries
