Spark knock - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2007, 10:22 PM   #1
Rainbird1099
Titles are over rated
Send a message via Yahoo to Rainbird1099
Default Spark knock
I am getting what I believe to be spark knock in my girlfreind's 93 Tempo.
I originaly thought it was the power steering pump, by identifying the knocking sound with a wooden dowel rod.
The car knocks at idle, and when under load (wheel locked, or heat / ac on).
It give a slight knock occasionally at idle, loud when under load, or in neutral at idle.
I have cheacked the air filter, and have cleaned the Mass air flow sensor (with elictral spray contact cleaner).
There is a second sensor at the other end of the air duct that the MAF is on.
Unless someone else has an idea, next I will clean this sensor, and re-clean the MAF.
Thanks in advance.
Scott
Rainbird1099 is offline   Reply With Quote
Old August 20th, 2007, 10:26 PM   #2
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
I'd look deeper into the engine for that knock.
Bottom end would be my first guess...
Old August 20th, 2007, 11:02 PM   #3
Smiley23
Smiley23's Avatar
There are a few things that can throw you off on a knock.
Is it loader when the engine is cold? - Exhaust gasket.
Tried high octane fuel and it went away? or minimized?
Edit:
Oh - 93 Tempo - scrap it - jk
I did however see a lot of those engines take a crap - lots of airflow through the valve cover (oil fill) was the first clue.
Smiley23 is offline   Reply With Quote
Old August 21st, 2007, 12:10 AM   #4
Rainbird1099
valve cover does not look great. I will try premium gas, and see, as far as if it does it more when cold I will drive it for a couple of days and see.
The car overall is in good shape less than 80k on it.
I don't think I mentioned, when I took the belt off and started it, the sound was gone, that is why I started looking at external components, and ruled out the concerns in the block.
I then did the back yard Mechanic's trick of listening with a dowel rod, to try to pick up the knocking. From this it sounded like it could have been the power steering, or the a/c unit. Power steering pump was more crucial, I tried that one first.
Thanks again for the help and suggestions.
Old August 21st, 2007, 11:25 AM   #5
Smiley23
Smiley23's Avatar
Then that would make sense to be an external accessory. AC Compressor - common.
Old August 21st, 2007, 03:47 PM   #6
Rainbird1099
Any way to verify it is, before I spend the time and money to replace the "chance" of that being it?
Old August 21st, 2007, 04:11 PM   #7
biohazardbill
The Biohazards
biohazardbill's Avatar
get a belt for a non ac car and bypass the ac unit
biohazardbill is offline   Reply With Quote
Old August 21st, 2007, 04:14 PM   #8
Bones
Bones's Avatar
AC and PS pumps will knock
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 21st, 2007, 08:06 PM   #9
bj house
bj house's Avatar
look for a wobbly pulley. Or engage the AC compressor and listen for a change. Or turn the wheel to lock load the PS pump and listen for a change
Page generated in 0.36931 seconds with 50 queries
