Vibration felt in rear at 70-80 mph only - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 27th, 2006, 07:13 AM   #1
mrclean
Silver Lake
mrclean's Avatar
Default Vibration felt in rear at 70-80 mph only
I have a 97 TJ with a small lift and slip yoke elimator that have been on for some time. Just noticed lately that starting slightly at 55 mph, more pronounced at 70-80mph. If I disengage the clutch, the vibration is still there. Any suggestions, I'm thinking pinion bearing but thought I would get some other ideas first.
mrclean is online now   Reply With Quote
Old February 27th, 2006, 09:00 AM   #2
Bones
Bones's Avatar
do you feel the vibes through the body of the jeep? Through the steering wheel? Through the trans lever (if you had a manual)?
Have you rotated the rear tires to the front?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 27th, 2006, 09:10 AM   #3
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
! dont drive 70-80 .. not sure of any place in michigan where the speed limit is above 70 :P
nixxerRsixxer is offline   Reply With Quote
Old February 27th, 2006, 09:13 AM   #4
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
If you only feel the vibration in your rear......look behind you.....it's probably cube
Old February 27th, 2006, 09:26 AM   #5
Things to try:
#1) Inspect rear driveshaft U-joints
#2) Remove rear driveshaft and check for play in SYE and pinion yoke/bearings
#3) Rotate tires, inspect for crap in the rims and drive that setup to test.
You could try pulling the rear shaft and driving in 4wd at 65 mph if your front shaft doesn't also have balance/vibration issues.
Old February 27th, 2006, 10:05 AM   #6
mrclean
Silver Lake
mrclean's Avatar
I feel the vibration in the back of the seat, rear center console area (where my arm rest). I did move the tires around and it didn't change. The rear u-joints feel tight but I have not removed the rear shaft yet. Did not feel any play in the slip yoke either. Rear pinion had a little movement up and down.
Old February 27th, 2006, 08:04 PM   #7
JEEPR
Playing Possum
JEEPR's Avatar
Sounds like tire balance to me.
JEEPR is offline   Reply With Quote
Old February 27th, 2006, 08:16 PM   #8
revho
$9.00 vanilla malt
revho's Avatar
lets open the floor to wild speculation. I will throw out that it might be a family of opposums squating in your axle.
revho is offline   Reply With Quote
Old February 27th, 2006, 08:22 PM   #9
nixxerRsixxer
Homewrecker
no way.. its a family of badgers that have burrowed into each seat..
Old February 27th, 2006, 08:35 PM   #10
revho
$9.00 vanilla malt
revho's Avatar
sorry, but you knew this was coming
http://www.albinoblacksheep.com/flash/badgers.php
Old February 27th, 2006, 10:05 PM   #11
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Damn you Sandles...you beat me to it.
Oh.....and you drive your Jeep 80? Maybe you need bigger tires.
Old February 28th, 2006, 07:13 AM   #12
mrclean
Silver Lake
mrclean's Avatar
Thanks guys, I checked last night and it was a dancing family of badgers . Pest control is coming to remove them today.
And no, I don't think tire size has anything to do with it. I run a 33 and it only turns 2300-2500 rpm at 70-75mph.
Old March 1st, 2006, 09:29 AM   #13
Pongking23
CHOP'S Idol
Pongking23's Avatar
Send a message via AIM to Pongking23
i agree.......this is what happened to my TJ. between 55 and 60 i was getting a vibration, it was actually time to get new tires but the guys at the tire place said it was because of the balancing of the tires, they coulda re-balanced the old tires but i got new ones and the vibration went away immediately. Try it, it is a cheap fix if it works out, if it doesnt fix it i dont know i am not a mechanic
Pongking23 is offline   Reply With Quote
Old March 1st, 2006, 09:12 PM   #14
JEEPR
Playing Possum
JEEPR's Avatar
this may sound odd (well, not as odd as badgers or opossums) but check your front wheel bearings if your still running the dana 30.
Old March 3rd, 2006, 06:32 AM   #15
Jetblackxj99
What rear axle do you have??
-I would swap around the tires and see what happens......
Jetblackxj99 is offline   Reply With Quote
Page generated in 0.28134 seconds with 68 queries
