what 44 for a tj build? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2007, 03:03 PM   #1
LS1CJ5GIRL
Default what 44 for a tj build?
I am looking for a dana 44 to replace the 30 in my tj. What would be best to start with? I want to end up with the 5 on 5 pattern so I can match a set of aftermarket axles on my 44 rear axle.
LS1CJ5GIRL is offline   Reply With Quote
Old August 20th, 2007, 03:12 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
How much work do you want to do?
Easiest= 80-91 waggy axle converted to 5x5.5
Best= a 76-77 hp44 out of a F-150 narrowed to 80-91 waggy axle width or use rubicon 44 inners
Old August 20th, 2007, 06:36 PM   #3
mudd_jumper
mudd_jumper's Avatar
I am going for the essayist and leavening it at 6 lug
Old August 20th, 2007, 09:56 PM   #4
LS1CJ5GIRL
I just picked up two hp 44's from a ford 1/2 ton.
Old August 20th, 2007, 10:03 PM   #5
For clarity, are you looking for a 5 on 5" (JK) or a 5 on 5.5" (CJ) pattern?
Page generated in 0.24305 seconds with 38 queries
