Accessing Engine Codes on Ford - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Ford Tech > FAQ's
Old August 20th, 2007, 01:06 PM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default Accessing Engine Codes on Ford
It's a 1992 Ford Explorer. How does one retrieve the engine codes on this motor?
Old August 20th, 2007, 01:10 PM   #2
Monster4.0
Monster4.0's Avatar
Go to Autozone.
Old August 20th, 2007, 01:31 PM   #3
shawn
shawn's Avatar
It won't start
Old August 20th, 2007, 02:11 PM   #4
Smiley23
Smiley23's Avatar
You can buy those cheap code readers. Is it ODI2? If it is the old style with the 2 connectors under the hood. There is a way to use a multimeter and jumper a wire.
Smiley23 is offline   Reply With Quote
Old August 20th, 2007, 02:14 PM   #5
Cartman
Can't lose with 42s
Cartman's Avatar
Is the fuel pump kicking on?
if not, get a BFH and hit the damn tank, try rotating the key switch about 400 times also.
gay exploders are common for this.
Could also be the fuel pump relay. ohm out the contacts.
If it wont start, odds are pulling the codes wont do much for ya
good luck
Cartman is offline   Reply With Quote
Old August 20th, 2007, 02:21 PM   #6
bj house
bj house's Avatar
This should cover it for your 92
http://autorepair.about.com/cs/troub...l_dtcs_18a.htm
Old August 20th, 2007, 02:27 PM   #7
Bones
Bones's Avatar
i have a scanner.
92 is OBD1 - EEC4
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 20th, 2007, 04:49 PM   #8
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Originally Posted by bj house View Post
Thats the ticket. This will also get the check engine light to flash too so you can count the flashes. I don't know why the instructions don't mention anything about watching the CES light on the dash. The '94 Tempo I just sold has the same code test and the CES light flashed along with the meter needle sweeps.
It can be tricky trying to count the sweeps of a meter. FYI, the meter sweeps don't go the full distance of the meters guage. The first sweep goes all the way, then the needle stays in the upper range and bounces with the pulses.
Old August 20th, 2007, 09:46 PM   #9
Smiley23
Smiley23's Avatar
Nice link - thx BJ - that was exactly what I was thinking - but stuck at work with firewalls up the WAZU.
Page generated in 0.22396 seconds with 50 queries
