D44 seals - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2007, 11:22 AM   #1
Default D44 seals
got everything i need to do my gear swap in my 77 F150 D44 except new seals at the diff/carrier
Napa can't find the seals (don't list them) nor can carquest
anybody got any help on this, i don't wanna get them online cause i wanna do the swap tomorrow on my day off and i have already been waiting a couple weeks on parts etc.....
Old August 20th, 2007, 11:28 AM   #2
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I have d44 seals here... but I am not sure if ford is the same as Jeep/Chevy. If you can verify that, and the parts stores still don't list the seals I would be happy to sell you two. If I get them in the mail before 4, you will have them tomorrow.
JcrOffroad
Zoom Zoom!
Old August 20th, 2007, 11:45 AM   #3
clarkstoncracker
lol
clarkstoncracker's Avatar
Is this in a vac disconnect 44, or a normal one?
jeep or ford?
I have a list of parts that I've ordered for mine w/part numbers
Old August 20th, 2007, 11:48 AM   #4
:miff:
Old August 20th, 2007, 11:57 AM   #5
or even part numbers to cross reference
i ran into the same prob when i swapped gears in my TTB D35, i ended up getting pinion nut and crush sleeve for a XJ D35 cause napa didn't list a Ford D35
and its a non disco (i can't say i have ever seen a disco ford before?)
Old August 20th, 2007, 12:17 PM   #6
clarkstoncracker
lol
yeah, I didn't read the ford part.
http://broncograveyard.com/bronco/i-...seal__each.htm
Call them and ask them what the spicer number is
Old August 20th, 2007, 12:19 PM   #7
they list a different seal for the F150/ Full Size Bronco D44's, and i already took their number and cross refernced it to Napa and all i got were air filters
http://broncograveyard.com/bronco/i-...-79_bronco.htm
Old August 20th, 2007, 12:41 PM   #8
n8big
Size Matters
n8big's Avatar
Send a message via Yahoo to n8big
do you have an old seal?
there is 2 different seals!!!
1 with a 2.625 od and 1 with a 2.286 od
NAPA does list them... whoever you talked to is an IDIOT!!!
n8big is offline   Reply With Quote
Old August 20th, 2007, 01:40 PM   #9
i don't doubt that, i searched on their website napaprolink and couldn't find it either, i'll have to measure the axle shaft sealing surface, but i'm sure its the larger
you got any part numbers?
Old August 20th, 2007, 01:46 PM   #10
scorpio_vette
scorpio_vette's Avatar
Send a message via MSN to scorpio_vette Send a message via Yahoo to scorpio_vette
call the dealership, get the factory part number, then start cross referencing it with the local parts store. or try looking up Jeep Grand Wagoneer, 87 XJ, 97+ TJ, 03+Rubicon (yes i know it's still a TJ, but different 44), and check them. i wouldn't be surprised if one of their 44 seals would fit.
scorpio_vette is offline   Reply With Quote
Old August 20th, 2007, 02:16 PM   #11
n8big
Size Matters
n8big's Avatar
the axle shaft seal surface is the same.. it is the outside diameter that is the diff...
NAPA PART #13165 or NAPA PART #13246
hope it helps!!!!
Old August 20th, 2007, 02:27 PM   #12
thanks
Old August 20th, 2007, 05:38 PM   #13
sodapop
Support the Sport!
sodapop's Avatar
The ones that went in my Waggy 44 are these
spicer part # 620257
they looked like these:
if yours looked like that coming out, they are the same diameter for both sides of the differential. unlike NAPA or any other part store will tell you. Some 44's do have differences but not all.
Old April 28th, 2008, 07:48 PM   #14
hope it helps!!!!
Didn't end up replacing the seals before, but now they have started to leak, so they need replacing asap since i leave in three days for attica.
i got the 13165 today and it doesn't match and won't fit my axle. The one i pulled out look nothing like the 13165. Heres the old seals next to the 13165 seal
the best measurement i could get with my micrometer of the axle bore where the seals sit was 2.187" and the old seals on the outside edges measured approc 2.210 but those were a little deformed since i had a hell of a time getting them out of the diff housing.
Broncograveyard shows this seal
looks like i may have pulled the seal apart from itself, gonna run back out and look at it closer.
Old April 28th, 2008, 08:06 PM   #15
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
John i have run the napa seals in the 78-79 axles and they work good. I had the same problem with daves when i went to put his gears in. Rich had to get some other seals from the part store. Im sure you will be able to get some in a day or so.
Old April 28th, 2008, 08:18 PM   #16
i just went back out and this IS the seal i have in my truck....
the 13165 seams to fit in the housing and it fits over the shaft.....should still seal, maybe a redesign?
Old April 28th, 2008, 09:03 PM   #17
Fullsize4life
Kicking Cancers ASS
Yes they changed them ove the years
Old September 5th, 2008, 10:03 AM   #18
update from my stupidness, when i pulled my seals out of the housing the cone shaped steal part stayed in the axle and just the seal came out. Thats why in an before post in this thread they did not look the same.
Page generated in 0.36350 seconds with 77 queries
