Need answers on a 1995 F-250 with 7.3L Turbo - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2007, 12:06 AM   #1
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Default Need answers on a 1995 F-250 with 7.3L Turbo
I'm going to take a look at this http://cincinnati.craigslist.org/car/401027926.html
tomorrow. What should I look for and what should I watch out for that would want me to back away from the truck as fast as I can!!
It has 119,000 miles on it. It would be pulling a 2006 Unlimited to the trails and back.
Thanks in advance to all you diesel guys!!!
Old August 20th, 2007, 12:37 AM   #2
Bones
Bones's Avatar
-Make sure it hasn't been started yet that day. When you get there, count how long the 'wait to start' light stays on. 8+ seconds is normal and means at least 6 plugs are woring correctly. 2-3 second means at least 2 glow plugs are bad. less than that or a clicking noise means the glow plug relay is bad. When it starts, look for smoke exiting the tailpipe for the first 30 seconds or so, that is another good indication of glowplug conditions. If it smokes just for the first 20-30 seconds, it;s fuel (glow plugs), if it smokes for a few minutes then stops, it might be oil (blowby). That scenario really isn't a bad deal though. If it smokes longer, you have bad injectors/bad blowby
-fuel leak in the engine valley, might even drip down the trans bellhousing ($100 lift pump + 4 hours labor) or fuel bowl crack (anywhere from $50-$600)
-endplay in the turbo impellor shaft (rebuilds are only ~$300)
-abnormal wear of turbo impeller from bad air filter/cracked intake box (was a recall)
-Ask him about using diesel coolant (different than normal coolant). Not using the right coolant can cause cavitation and damage to the walls
-play in front end components. Should be able to feel vibes. In any case, the 2wd front end is cheap to rebuild
-hopefully the new clutch was upgraded over stock
-test the fuel tank selector switch
buy it, then-
tymar intake $140
downpipe and exhaust $450
Tony Wildman chip $400
and you'll be amazed
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 20th, 2007, 06:10 PM   #3
Chiefwoohaw
Thanks Bones. I'll keep ya updated . . . sounds like you've had one before!
Old August 20th, 2007, 06:30 PM   #4
Bones
Bones's Avatar
had one, just bought another
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 20th, 2007, 07:25 PM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
LOL.
BTW, it's weird that it is listed in the Cincinnati craig's list, but is in Milford.
Also, it is a 2wd 5-speed - that's what I have (but a 1996) and I can get 21 mpg unloaded / 17 mpg hauling my truck camper and a 6x10 enclosed motorcycle trailer as long as I stay at 2000 rpm or below (3.55 gears = about 65 mph @ 2000)
Ask these questions about the tranny/clutch:
Why was the trans replaced?
Does it have a new clutch?
Is it a single mass or dual mass flywheel?
Dual-mass flywheels are stock. They work well for 30k to 100k miles, and then they die. You get some warning (do a search on thedieselstop.com for "DMFW"), but when they let go, they take the bellhousing out. The ZF 5-speed has an integral bellhousing, so this may be why it has a new trans.
Dual-mass flywheels are almost always changed out for a single mass unit - the trans/clutch will be a lot noisier with a SMFW, but it will be bulletproof. My truck had 2 DMFW that lasted about 60K each before they got swapped out. The first time was under warranty, the second time I installed a SMFW and clutch kit from south bend clutch for $700 parts.
The stock clutch isn't much good for more than 250hp - I did all the mods bones suggested above and ended up slipping in 3rd gear and higher. The DMFW was also getting real noisy, so I replaced it all.
Another thing to keep powerstrokes happy is oil changes religiously at 5k and fuel filters every 10k. The HEUI injectors use engine oil pressurized to ~1800 psi to fire the fuel inside the injector; these pressures plus the shear the oil goes through breaks it down quickly.
At 119k, you're probably close to needing a waterpump, they can be had for about $160 if you know where to look, don't go to a dealer or you may die when you see over $400 for parts.
Bones mentioned glowplugs - you should change them if they're old; about $10 at autozone for the preferred autolite (beru) parts. takes a couple of hours and some patience to swap them out. Use a light touch when taking them out - some can become carbon fouled and be tough to get out. What usually happens is that someone reefs on them, and the tip breaks off and falls into the cylinder. That always winds up in pulling the cylinder head off.
Good luck - I love mine, Bones loved his, regretted selling it and now has another.
@clarkstoncracker
Old August 20th, 2007, 07:46 PM   #6
Bones
Bones's Avatar
ONLY BUY BERU OR MOTORCRAFT GLOWPLUGS
We need a glowplug swap party, I need to do mine but have never done it.
I can swap a lifter pump in about 90 minutes with the right tool though haha
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 20th, 2007, 09:42 PM   #7
Chiefwoohaw
It's in Milford, OH not Milford, MI
It already had the water pump changed and the glow plug relay changed.
I'm just sent an email on the flywheel. It was a beater but it started right up and didn't smoke a bit. This kid went to diesel school for two years or so he says. The body and interior is ROUGH but the truck is only $2500. The exhaust needs to be completely replaced. There was no play in the turbo. The valve cover gaskets were just done with a new injector harness.
Another thing that I'm concerned about is that it doesn't shift into gears that easy and he said something about new syncros . . . I thought it would shift really easy with those but it does shift. The clutch grabs right at the floor. I thought it should grab at the top but I don't know on that either.
The trans is the ZF 5-speed. He went through two (the orignal and a cheepy from the junk yard) autos and said F**K it and put the ZF in. It still has the colum shifter
Thanks once again for the insight and please give more!!
Old August 20th, 2007, 10:09 PM   #8
TurdBronco
Im in. I've had my truck a few years and never done them. Like to before winter.
I wish i had a 5 speed. Stupid E4OD
2500?? Sounds cheap. I paid 400 bucks for my exhaust and it made a noticeable turbo difference. Spooled much faster and made me wish i had it put on the day i bought the truck.
Old August 20th, 2007, 11:01 PM   #9
Bones
Bones's Avatar
Scott, lets us know when you can take us through changing the plugs ahahha
and I'll take you through the lift pump R&R
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 20th, 2007, 11:05 PM   #10
Chiefwoohaw
He started the price at 5,000 but it's REALLY REALLY UGLY!! So not it's at $2500
Old August 21st, 2007, 06:52 PM   #11
TurdBronco
Thats real low miles for that type of truck. On the other hand I wouldnt cheap out on power windows, ac, those type options on something you'll be spending many hours in while towing.
Ugly rust wise?
Also, how hard is it to change the coolant? There's no freakin cap. Do you have to pull the lower hose and refill thru the overflow? If so, thats gay.
Old August 21st, 2007, 08:41 PM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
There is a little ball and socket on the clutch linkage that uses a plastic bushing to hold it in and take up slack - they go for about $5 and are always in stock...they go bad and your clutch gets sloppy and if they go real bad, the rod will fall out on the inside of the truck and the return spring will suck your clutch pedal to the floor and keep it there (stranding you in an intersection :tonka: )
As far as syncros, my third gear synchro is bad - partialy from the aforementioned bushing and partially from trying to shift it into third too fast while drag racing I've lived with the bad syncro for 50K - I just double-clutch and the trans snicks right into gear.
Exhausts are cheap - you can probably find one on e-gay for $400 or less. Don't bother with a muffler, just run 4" pipe out the back - the front end of the truck is so noisy, you won't notice any exhaust sound.
Glow plugs are a cinch after you remove the valve covers - especially on a truck that isn't intercooled. 10mm socket to get them out AFTER you use a mightyvac to suction out the oil sitting around the plugs. If you don't remove the oil around the plugs first, it will drain into your cylinder and you have the chance of damaging your engine when you crank it.
@clarkstoncracker
Old August 21st, 2007, 08:42 PM   #13
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Ugly rust wise?
There is a valve at the bottom of the radiator and the overflow also feeds directly into the coolant system.
@clarkstoncracker
Old August 21st, 2007, 11:00 PM   #14
TurdBronco
people next to you will almost enjoy your 4" straight pipe almost as much as you :tonka:
Old August 21st, 2007, 11:23 PM   #15
bj house
bj house's Avatar
x2 on the clutch grab mostly like worn out or hopefully just out of adjustment. Trans sounds ok with pulling the top or at least draining the oil and looking for metal chunks.
Pictures?
Old August 22nd, 2007, 08:05 AM   #16
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
The muffler on my truck is the stock free-flow - it's like a HUGE cherry bomb straight through design that doesn't quiet much down, and the engine still makes way more noise than the exhaust.
@clarkstoncracker
Old August 22nd, 2007, 12:16 PM   #17
TurdBronco
we need a diesel forum
UnlimitedLove, did you end up buying it?
Old August 22nd, 2007, 07:15 PM   #18
Chiefwoohaw
Picking it up tomorrow. Even it it's beat I can't see wrong picking it up with such low miles.
Geeezzz . . . way to many projects. I'll have pics of the body rebuild
Old August 23rd, 2007, 10:02 AM   #19
Big_Mack
Gotta love the BS
Big_Mack's Avatar
Send a message via AIM to Big_Mack
x2
Big_Mack is offline   Reply With Quote
Old August 26th, 2007, 12:48 PM   #20
Kane
Got Jeep?
Kane's Avatar
All you'll ever need to know about Ford diesels:
http://www.thedieselstop.com/
http://forums.thedieselstop.com/forums/
Kane is offline   Reply With Quote
Page generated in 0.56860 seconds with 83 queries
