1968 dana 70's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2007, 02:51 AM   #1
454 jeep
454 jeep's Avatar
Default 1968 dana 70's
What do you think, or have to say about a 70 front? Drum brakes, 4.88 gears. Also have a 70 rear with the same gears. I cant find much about them. There from a 68 one ton. YES or NO?????
454 jeep is offline   Reply With Quote
Old August 17th, 2007, 03:13 AM   #2
jeeptjpaul
jeeptjpaul's Avatar
What are you thinking about putting them in? Your CJ?
jeeptjpaul is offline   Reply With Quote
Old August 17th, 2007, 03:21 AM   #3
454 jeep
454 jeep's Avatar
Yep. 454 with 44's
Old August 17th, 2007, 03:29 AM   #4
jeeptjpaul
jeeptjpaul's Avatar
Go for it. Put some disc brakes on the front. It's not like ground clearance is much of an issue with 44's.
Old August 17th, 2007, 03:37 AM   #5
454 jeep
454 jeep's Avatar
Its the closed knuckle style...Can I put disc on it? I've never worked with a closed knuckle before. Looking at it I cant see how you would do it. My only issue with it would be parts. where would you get them? Should I go this way,or find some rocks? I'm looking for something that I can just get in and hold it to the floor.
Old August 17th, 2007, 06:43 AM   #6
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Not worth the trouble. Get a more modern front axle for it.
Old August 17th, 2007, 09:03 AM   #7
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
X2 most likely the joints in the front axle are the size of a dana 44 :miff:
Old August 17th, 2007, 09:29 AM   #8
snocross2xtremes
snocross2xtremes's Avatar
there junk! and they bend really ez.
Old August 17th, 2007, 09:49 AM   #9
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Using my cereal decoder ring, I found that this actually translates to:
They're junk, and they bend really easy.
You're welcome. :tonka:
Craig
Old August 17th, 2007, 10:09 PM   #10
PavementPounder
PavementPounder's Avatar
The axle shafts are most likely not hardened like modern ones and are low-spline, also. They'll hold up to some shit, but not like you want to use them for.
Old August 17th, 2007, 10:18 PM   #11
454 jeep
454 jeep's Avatar
Thanks for the input.
Page generated in 0.28158 seconds with 56 queries
