Running Weird. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 15th, 2007, 11:50 AM   #1
guest
Send a message via AIM to guest
Default Running Weird.
I have a 1997 Dodge Ram 1500 4x4 with the 5.2L(318). I just did a tune-up on it and it ran fine for a couple days. Then the check engine light came on but then shut off a little bit later fter the truck sat. I think the truck reset the Check Engine after so many starts. I think its like four cranks and if the problems gone the light shuts off. but anyways I did the tune-up friday. It ran fine friday,Saturday, and then Sunday after noon I got on it a little bit and it fell right on its face. So I amde it home and screwed with it a little bit. If I bring the RPMs up slowly its fine. But if I hit the gas to Hard it wants to stall. Also I have a really hard time starting it. But when it starts it idles perfect. Anyone got any ideas??
Thanks, A.J.Hall!.
guest is offline   Reply With Quote
Old August 15th, 2007, 12:19 PM   #2
84Scrambler
Sounds like a fuel pump.
Old August 15th, 2007, 12:57 PM   #3
guest
Thats what I was thinking to. But im gonna go for fuel injectors first. i think thats it cause I cleaned four of them and its already running alot better now.Thanks though.
A.J.Hall!.
Old August 15th, 2007, 05:32 PM   #4
guest
k well fuel injectors are clean and the truck still sucks. Idk. Whats the odds that it could be the fuel pump?
Old August 15th, 2007, 09:34 PM   #5
user name
keep your stick onthe ice
user name's Avatar
Does it bog down then act normal? If it does that i would think TPS, All the check engine light talk has me confussed is it on right now??? Even if it's not on now you should be able to get it scaned and find out what set it in the first place.
Old August 15th, 2007, 09:36 PM   #6
88mudder
In the band!
prolly got water in it. Remember when i came with u last time my truck was boggin alot and hard starting i waited a week and it cleared itself out.
Old August 15th, 2007, 09:40 PM   #7
user name
user name's Avatar
that is so simple it makes a lot of sence, run a bit or drygas through it if you dont feel like waiting.
Old August 15th, 2007, 10:14 PM   #8
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Key on/off three times. A P code will display in the odometer, if you have a digital one. Post the code and we'll let ya know what to do.
You can always go to AutoZone and they will check MIL's for you.
Old August 16th, 2007, 11:46 AM   #9
guest
Ok well I went to Autozone they ran the code and it had seven codes 6 of them were for cylinder mis-fires and the other code said Random Multiple Cylinder Mis-Fire. So he cleared the code. But when ever i hit the gas to hard to where it wants to stall the check engine light comes back on. But if I bring the RPMs up slowly the Chewck Engine Light Stays Off. Also, the truck is really hard to start and once you get it started and you shut it off its pretty easy to start back up but if you wait like 10 minutes to start it back up its really hard to start again. One more thing, I cannot go over 50MPH no matter what I do. I think i need to start driving the burban again.lol.
Old August 16th, 2007, 11:47 AM   #10
guest
I dont have a digital odometer but thanks anyways. and what is dry gas?
Old August 19th, 2007, 09:25 PM   #11
user name
user name's Avatar
ok long shot but mud in you flexplate windows just popped into my head. The crank sensor sets the MIL for misfires and tells it when to spark a fuel each cylinder. Im not sure that mud would really mess up its reading. you dont happen to be missing the inspection cover do you?
Old August 19th, 2007, 11:16 PM   #12
guest
whats that?lol. weres it at?
Old August 20th, 2007, 03:26 PM   #13
sonic
sonic's Avatar
Did your battery go dead ever during this? If so this is your problem and you need to let the PCM re-learn its perameters. Happens to me all the time with my truck. I need a "shut off your fog lights dummy" sign or something. It will as stated before act this way from an alternator going bad as well. Found that out my first time at the mounds. Also since you just did a tune up I would Also suspect water getting underneith the Cap and causing misfires. A little di-electric grease and some silicone spray on you wires plugs and cap goes a LONG way in the water. Make sure that cap is screwed down tight and rememeber Dodges HATE water for many reasons. Oh yeah another place to check is your coil. Also a leaking intake. Should drain your oil and see if there is any water in there as well.
sonic is offline   Reply With Quote
Old August 20th, 2007, 03:42 PM   #14
guest
well the battery died trying to start it.lol. now it wont even start. but it never just died while running it would always crank good for like 3-5 minutes right after i shut the truck off.
Old August 22nd, 2007, 06:38 PM   #15
guest
anyone think it could be the alternator? cause as you increase the RPMs the alternator has to send more power. Higher the RPMs the more the truck doesnt want to run right. My uncle told me to disconnect the battery see if the truck stays runnin if it does turn a bunch of accessories on and see what happends. well the alternator guage droped to about 12 or 13 and it ahs to be at 14.2 Volts constintly.(spell??) So what do you all think?
Old August 25th, 2007, 12:45 AM   #16
user name
user name's Avatar
what collor is your oil and does it smell like gas? any resent drops in gas milage? can you get a fuel pressure gauge?
Old August 25th, 2007, 12:47 AM   #17
user name
user name's Avatar
also do you have one or two fuel lines going to you fuel rail? pull a plug and see if its black, white, or oily
Old August 25th, 2007, 11:31 AM   #18
guest
Well I realized I am getting fuel because after cranking it awhile I can smell it. But I put the new 134 AMP Alternator on. Then took the big brand new battery out of the Burban and put that in there. Charged it. Got it to crank good. But it wont start. It just cranks and cranks and cranks. So I poured a little gas down the throttle body and still no start at all. Its doesnt even sound like its trying to start. So i pulled a plug and wire and grounded it and I ahve spark but its kinda more yello colored spark than a blue colored spark. Which means my plugs are pry fouled out. So i pulled all the plugs and of course there all black and fouled so now im gonna try to find a way to Autozone.lol. I guess these Bosch Platinum plugs are not really good for anything but performance Automobiles. But i know now that I have Spark, Fuel, and Oxygen. So im gonna try changing the plugs. Hopefully this works.lol. PRAY please. Im sick of this truck.lol.
Old August 25th, 2007, 11:50 AM   #19
dodgeboy
redneck truck club
dodgeboy's Avatar
bosch is junk put what came from the factory in it "Champion" and once you get it running hows the exhaust flow? dont go over 50 mph sounds like the beggining of a clogged cat.
dodgeboy is offline   Reply With Quote
Old August 25th, 2007, 03:02 PM   #20
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Xeleventy kabillion.
Quit screwing around with everything else, and check the pump and filter. :miff:
Page generated in 0.41428 seconds with 83 queries
