Dana 60 disk brake swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 14th, 2007, 09:20 PM   #1
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Default Dana 60 disk brake swap
Need some info on putting some disk brakes on the rear 60 in my bronco. The cheaper the better. Thanks
Old August 14th, 2007, 09:25 PM   #2
zekexj
brakes are for pussies!
zekexj is offline   Reply With Quote
Old August 14th, 2007, 09:38 PM   #3
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
GreatLakeOffroad.com has the brackets and then late 70's chevy caliper rotors.
Old August 14th, 2007, 11:27 PM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
http://www.greatlakes4x4.com/showthread.php?t=31308
Old August 15th, 2007, 07:08 PM   #5
Fullsize4life
Kicking Cancers ASS
Thanks guys, Zeke your gay!
Old August 16th, 2007, 12:49 PM   #6
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
There's a guy on Pirate selling complete disc brake kits for $297 shipped. He has them for 60's and 14b.
Old August 17th, 2007, 12:51 PM   #7
liv2mx
i like jungle gym's.
liv2mx's Avatar
colin call me i have all the numbers. you can go bolt on or weld on for brackets. get chevy front calipers. can do the whole thing for like 70.00.
Old August 17th, 2007, 09:26 PM   #8
Fullsize4life
Kicking Cancers ASS
Cool, I dont have your new number.
Old January 27th, 2008, 06:45 PM   #9
Fullsize4life
Kicking Cancers ASS
I got some 77 k20 rotors and 86 front brackets and calipers. Any mods needed to put the rotors on the hubs? Do the rotors go beheind or on the outside of the hub?
Old January 27th, 2008, 10:34 PM   #10
s.hembree
s.hembree's Avatar
I just did the swap with the brackets from Great Lakes. They had a deal going on Pirate for $45 shipped. Used the same rotors and calipers as you bought. Rotors went on the back of the hub just like the factory drum. I have roughly $150 invested, not including the new bearings and seals for the hubs. Reused the original wheel studs also, seemed to fit great...
Old January 27th, 2008, 10:36 PM   #11
bigcountrysg
Countryboy
bigcountrysg's Avatar
I would have went to a junk yard. Found a Ford that has a D60 under it 1999-newer. Then bought the brake assembly or whole axle from the junkyard. As the 99-newer fords that have the D60 have four wheel disc brakes.
bigcountrysg is offline   Reply With Quote
Old January 27th, 2008, 10:49 PM   #12
jeeptjpaul
jeeptjpaul's Avatar
Why? If all you need are inexpensive brackets and a few common, readily available parts, why bother with all the junkyard pieces? Sounds like a lot more work, probably more money, and in the end, a less reliable setup due to having used junkyard stuff instead of new parts.
jeeptjpaul is offline   Reply With Quote
Old January 27th, 2008, 10:54 PM   #13
bigcountrysg
Countryboy
Considering the 99-newer fords are so new I doubt it would be unreliable. I also doubt it would be a waste of time and money. Different people have different ways of doing things. You have your way I have mine, they both work and both are equal but still different.
Old January 28th, 2008, 06:50 AM   #14
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
...and a completely different (metric) bolt pattern.
Old January 28th, 2008, 06:54 AM   #15
PavementPounder
PavementPounder's Avatar
They're sure different alright, but certainly not equal. His would work and yours would not. 99-up Ford 8-lug axles have a metric bolt pattern, assclown.
Edit: Damn you Cooter. I've been re-writing my smart-assed reply for like 10 minutes.
Old January 28th, 2008, 07:06 AM   #16
Cooter
Cooter's Avatar
:tonka:
Old January 28th, 2008, 09:22 AM   #17
Fullsize4life
Kicking Cancers ASS
Thanks guys i think im good to go.
Old January 28th, 2008, 10:29 AM   #18
jeeptjpaul
jeeptjpaul's Avatar
Yeah, a 99 is now at least 9 years old. I don't consider that so new that it would be totally reliable.
Old January 28th, 2008, 04:42 PM   #19
Fullsize4life
Kicking Cancers ASS
Ok well i went to put eveything together...........And It does not seem to work out quite so well. I have the front chevy Brackets off of a 1/2 ton. What is needed to be done to make these work on the 60 rear. Am i missing something or what? Does anyone have any pics of these brackets on a FF dana 60 rear?
Old January 28th, 2008, 06:36 PM   #20
Jeepaholic
Jeepaholic's Avatar
Buy the right brackets
http://www.greatlakeoffroad.com/disc.html
Page generated in 0.54106 seconds with 83 queries
