Strength of 5.13's in Rubi D44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 14th, 2007, 06:38 PM   #1
mzy4v1
40's baby!
mzy4v1's Avatar
Question Strength of 5.13's in Rubi D44
Has anybody had / or heard of any issues with running 5.13:1 gears in Rubicon D44 axles?
I am thinking about regearing to 5.13's, but I am concerned they may not be so strong due to the size of the gear and thus the smaller size of the teeth....and we all know it's all about the size of your toys
Any comments / input would be appreciated.
mzy4v1 is offline   Reply With Quote
Old August 14th, 2007, 07:24 PM   #2
PavementPounder
PavementPounder's Avatar
I'm kind of curious as to what kind of wheeling you're doing with the tire size in your avatar that you need 5.13's in a rig that already has a 4:1 case?
Anyway, yes - the teeth are staring to get small at that point, but do you have the power to break them? I run 5.13's, but that's in a 60/70 combo. I think I might lean towards more power and less gear with smaller axles so something else breaks, like a lockout or a u-joint.
Old August 14th, 2007, 07:33 PM   #3
mzy4v1
40's baby!
mzy4v1's Avatar
I'm currently running 35's but I have just picked up a set of 37's
I am still running the 4.10 gears and really find the rig bogs down on the freeway, thus it will be even worse with the 37's. Maybe 4.88's would be enough but the 5.13 will get me almost exactly back to the stock rpm's in 5th gear with the 37's.
Old August 14th, 2007, 07:39 PM   #4
PavementPounder
Are you running an auto or stick?
Old August 14th, 2007, 07:41 PM   #5
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
id be more worried about your dana 30 outers than a 5:13 gear set. either way 5:13 seems like its gonna be real low with 37's i would go 4:88
Old August 14th, 2007, 08:22 PM   #6
sodapop
Support the Sport!
sodapop's Avatar
Don't know if you need a gear that low or not but I run 5.13's in my front 44 (waggy) and I'm not worried about the ring and Pinion. I'm pretty sure I'll dump some u-joints or lockouts before the R&P goes. What I'm not sure in your case is how the Rubicon thick cut 5.13's compare to the standard cut 5.13's Running the numbers in a gear calc. says 4.88's would put you back to stock.
http://www.4lo.com/calc/geartire.htm
Old August 14th, 2007, 08:28 PM   #7
Rubicon06
M-22
Rubicon06's Avatar
I would run the 5.13 with the 37s.
But I would definitely upgrade your axle shafts and get some beefy U-Joints too.
Try posting this over on rubiconownersforum too. ROF is another great offroad forum.
Rubicon06 is offline   Reply With Quote
Old August 14th, 2007, 10:11 PM   #8
Blackjackbender
i would be worrying about that 297x u-joint. i know mine dont hold for shit with my 37"s
Old August 14th, 2007, 10:14 PM   #9
mzy4v1
40's baby!
mzy4v1's Avatar
Pavement pounder: I am running a stick.
I am torn between the 4.88 and the 5.13. If I decide to go back to 35's later then the 4.88 would be better.
Old August 15th, 2007, 12:54 AM   #10
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I run 5.38's in my d44's.
I just cruise the malls though.
JcrOffroad
Zoom Zoom!
Old August 15th, 2007, 01:09 AM   #11
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
git some mad bishes yo
nixxerRsixxer is offline   Reply With Quote
Old August 15th, 2007, 09:31 AM   #12
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
sol goode and i think romey run 4.88's in their rubis with 37's and 35's without problems..
Well, except Sol Goodes trans going out :tonka:
Old August 15th, 2007, 09:44 AM   #13
87'YJ
Jeeps, Journey and Jesus
87'YJ's Avatar
I'm running 4.56's in my D44s and I'm using 38" tires.
Still goes 70ish on the highway (and its an 85 CJ, yours probably would have more power). 4.88's would be the lowest I would go.
87'YJ is offline   Reply With Quote
Old August 15th, 2007, 10:07 AM   #14
mzy4v1
40's baby!
mzy4v1's Avatar
Thanks for the insight, so far I am leaning towards the 4.88's
Old August 15th, 2007, 11:54 AM   #15
sodapop
Support the Sport!
sodapop's Avatar
I would have gone lower, like to 5.89's if they were available for the ford 8.8. But then again, I don't have you 4:1 t-case....
I know these aren't 5.13's but just to give you an idea of the guys I wheel with are running
4:88's with 4cyl non rubi 38.5" TSL front BoggerRear Wheeled HARD all day Waggy 44s front and rear. - No breakage that day. Jonathan's not broken a R&P yet but has spit out losts of u-jounts
4.88's with 4.0L non Rubi, 38.5" TSL's Stak monster box. Wheeled hard all weekend - No Differential Breakage. Scott's has fragged one R&P set.
Old August 15th, 2007, 01:01 PM   #16
mzy4v1
40's baby!
mzy4v1's Avatar
Thanks for the insight...nice pic's BTW.
Low range is defintely not my issue with 4:1 Tcase, it's the dogginess in 2wd hi.
Thanks again.
Old August 15th, 2007, 06:29 PM   #17
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
For an auto I would go 5.13's for a 5 speed man. 4.88, 6 speed 5.13
Old August 15th, 2007, 10:08 PM   #18
Blackjackbender
i brake a u-joint everytime i go wheeling with my 37"s on my 44. i think im cursed.
Old August 16th, 2007, 01:10 AM   #19
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Seriously.
I have been running the same set of cryo'd longfield 760 joints on stock shafts for 2 years now. 36 SXs, and I am not afraid to climb a ledge or a wall with the wheel turned either.
JcrOffroad
Zoom Zoom!
Old August 16th, 2007, 04:57 AM   #20
Jsawduste
Jsawduste's Avatar
Running 5.13`s with a 4.8 stroker and NV4500/Atlas on 37`s.
Havent broken anything but am in process of upgrading to HP60`s F/R.
But having said that. I would have changed to 5.38`s in a heartbeat.
Vote is for 5.38`s IF you plan on running 37`s or bigger. 5.13`s for 35`s.
Get chromo shafts/inners and outers. Buy the best U joints you can afford.
Jsawduste is offline   Reply With Quote
Page generated in 0.34056 seconds with 83 queries
