Scrambler 1/2 top cage - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 14th, 2007, 03:31 PM   #1
seddons
Seddons
Default Scrambler 1/2 top cage
I have a front roll cage in my CJ8 that I designed to be removed so I can use my 1/2 top during the cold Michigan winter months. Unfortunately that leaves me and a passenger unprotected during winter wheeling. I want to put a hoop behind the seats and in front of the stock roll bar to slide the top in between and tie together with the shoulder bolts. My question is has anyone tried this with the main hoop from a CJ7 bar? Just wondering before I cut the kick backs off and find out it will not work. Thanks for any responses.
Steve [/b]
seddons is offline   Reply With Quote
Old August 14th, 2007, 03:56 PM   #2
brimy311
Smells like a Fork Liftis
brimy311's Avatar
We have made one where the back of the cage slides into tubes welded to the B hoop. Then you bolt it all together. That way you can remove the back of the cage and pull the top, then bolt it all back together.
JcrOffroad.com
Like us on Faceook!
Old August 14th, 2007, 09:46 PM   #3
Bones
Bones's Avatar
rear hoop is a CJ7 hoop, front hoop is just an aftermarket CJ hoop....
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Page generated in 0.22835 seconds with 32 queries
