life of a 5.4 - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2007, 05:47 PM   #21
dgilham0401
dgilham0401's Avatar
Send a message via Yahoo to dgilham0401
I have a 2000 with the 5.4 as well with almost 125,000 on it and I have been wondering on the oil thing as well. NAPA says it should be 5w-20 but the shops all say 5w-30. Anyone have any idea what it should actually be?
dgilham0401 is offline   Reply With Quote
Old October 28th, 2007, 06:03 PM   #22
chris1044
chris1044's Avatar
Owners manual knows best, not the local lube tech at the quaker state quickie....
Per ford's tech site: 2000 F-150 with a 5.4 should take 5-30
Old October 28th, 2007, 06:12 PM   #23
dgilham0401
Well that's whats been put in it so at least that much is right. Thanks.
Old November 16th, 2007, 07:03 PM   #24
dgilham0401
Thumbs up Correct oil
Originally Posted by chris1044 View Post
Extremely important. I have seen some of these triton motors that will actually knock/tick severely with the wrong weight oil in them. From what I was told by a Ford engineer, the bearing clearance on them is extremely tight which is one of the main reasons 5-20 is needed.
Additionally, I have seen quite a few of these motors with timing chain issues - the guides seem to wear prematurely or the tensioner fails....but I'd say roughly 5% of the motors with this problem were actually maintained.....
Edit: look at the date on the original post
Exactly correct, I just got back from the Ford dealership and they told me the exact same thing. I have a 2000 F-150 with the 5.4 and it was starting to make that knock / tick so I asked what was the correct oil to be used in these motors. They said 1997 and newer 5.4 all need to use 5w-20 due to just that, the tighter bearing and valve clearance. I have over 125,000 on my motor and it rans great, I love it. Hopefully it will last even longer now that I know the correct oil to use and won't be letting those quick lube guys just shove whatever they have laying around in it.
Old November 16th, 2007, 10:13 PM   #25
tonka5
tonka5's Avatar
Send a message via Yahoo to tonka5
then why does the manual for my 97 say to use 5-30???
tonka5 is offline   Reply With Quote
Old November 17th, 2007, 09:47 AM   #26
dgilham0401
Because they changed the oil specification in 1999 I believe he said due to the amount of vehicles coming in with the knock / tick and found that a lot of the problems were caused by using the heavier oil. They updated their specifications and switched to 5-20. For more clarity I would suggest going to a dealership (which is what I did) or calling and talking to the service department and ask them to pull the new oil specification chart that they use. I guess that they found that the lighter oil increased gas mileage (minimally) and extended the engine life.
Old November 17th, 2007, 04:10 PM   #27
tonka5
tonka5's Avatar
mine doesn't have this noise problem yours does!!
Page generated in 0.34110 seconds with 44 queries
