SBC Clutch Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 25th, 2006, 03:13 PM   #1
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
Default SBC Clutch Question
Wasn't sure which forum i should put this in, so i put it here...
Mating a SM465 tranny to small chevy motor. Got everything i needed to bolt the rest up today, however when i bolted everything up, the throwout bearing would not reach the pressure plate?! It was extended almost all the way out, and it would catch maybe the last 1/4" of the stroke on the pressure plate fingers. Its almost like the pressure plate is not far enough out from the flywheel and disc setup. Does anyone know why this could be happening? Im thinking that i have the wrong pressure plate, but i didn't know that there were different ones other than the clutch size difference. I can post pics if you would like.
Thanks,
Chris
Old February 25th, 2006, 04:11 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
could be a couple of things. if you put the disc in upside down the presure plate may be compressed way to far, and it will NEVER disingauge. secondly is the clutch fork the right one for the trans? if you have the wrong fork then it won't extend far enough.
depending what set up you have I would expect the presure plate fingers should be right up even with the end of the input snout if you can see in the fork whole, if you see more then about 1/2" of spline then something is really wrong.
Yetti
Old February 25th, 2006, 04:21 PM   #3
PavementPounder
PavementPounder's Avatar
I would say Chevy Tech.
Old February 26th, 2006, 01:16 AM   #4
BigBlkYJ 355
U-Joints Fear Me
actually i think a friend of mine may have been on the right track. the throwout bearing he said might have been wrong. yes i have an oe throwout in there, however i think the clutch was made for a "long" version. i picked that up tonight, and am going to try it tomorrow. if that dosn't work i think i will buy an entire new clutch setup.
Old February 26th, 2006, 01:29 AM   #5
Yetti
Yetti's Avatar
now that you mention it there is two different Throw out bearings, one is the standard car one that is about 1 1/2 thick and the other is about 3" thick
Yetti
Old February 26th, 2006, 11:39 AM   #6
BigBlkYJ 355
U-Joints Fear Me
yea i had that standard one and it didn't work. seems gm used that in everything from like 1969 and up to around 89 or so. this new one is from a chevelle i think. i dunno they gave me the book and i picked it out haha. murrays was the only place open and if u dont know EXACTLY what it came out of ur in trouble. :tonka:
Old February 26th, 2006, 12:07 PM   #7
Yetti
Yetti's Avatar
if your set up is so old , do you have the stamped steel clutch fork or the cast steel one that reachs all the way acrossed the inside of the bell housing?
Yetti
Old February 26th, 2006, 01:31 PM   #8
BigBlkYJ 355
U-Joints Fear Me
This is a stamped steel one, its brand new i bought the throwout bearing, slave and fork brand new so that i would not have to deal with stuff like this Anyways i think the new throwout fixed it. It seems to be lined up right now, but i cannot test it until mumblies gets a master cylinder adapter in. So tuesday i should know for sure if its going to work. The only problem i see as of right now is there isn't really any clearance between the fingers and the throwout. i heard there was suppose to be like 1/16" or something like that. The throwout is not applying pressure, so its not holding it in or anything, its just going to spin all the time i think. a return spring wont help either.
Old February 26th, 2006, 01:37 PM   #9
Yetti
Yetti's Avatar
its ok that it touches, almost all hydrolic systems touch, if you had a mechanical one then it would have what we call "toe clearence" that is measured at the pedal. you should have full release within about 3-4 inches of pedal travel, so if its not releasing completely check everything real good.
Yetti
Old February 26th, 2006, 02:55 PM   #10
BigBlkYJ 355
U-Joints Fear Me
awesome, really appreaciate all the help
Page generated in 0.20942 seconds with 53 queries
