High pinion front? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 11th, 2007, 03:20 PM   #1
88yj
collecting parts
88yj's Avatar
Send a message via AIM to 88yj
Default High pinion front?
Anyone running a high pinion 3rd in their front axle? I've toyed with the idea of it, but I'm not sure it's worth the $$ to upgrade. Anyone know how much stronger it is? I assume the strength upgrade isn't significant and the main reason for doing it is driveshaft angle and slightly better clearance.
88yj is offline   Reply With Quote
Old August 11th, 2007, 04:32 PM   #2
Brimy was runnning an HP elocker I believe..
I just have a low pinion in mine, but I've rotating the housing 5 degrees up..
Old August 11th, 2007, 04:41 PM   #3
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Im also curious about this. Was thinking about doing it when i go though and do my axles since im going to have to redo the gears any way. Also what about doing a high pinion rear.
Old August 11th, 2007, 04:43 PM   #4
88yj
collecting parts
88yj's Avatar
HP rear is bad news. The gears make contact in the wrong direction/spots. HP is for front only.
Old August 11th, 2007, 04:47 PM   #5
Mud'N'Truck
Dont they make reverse cut gears for hp set ups so you dot have that problem.
Old August 11th, 2007, 04:49 PM   #6
88yj
collecting parts
88yj's Avatar
reverse cut gears are only stronger in the front. I'm not sure that there are even r/c gears for Toyota axles.
Old August 11th, 2007, 04:59 PM   #7
Mud'N'Truck
Yea there is. Know ive seen them before, think it was allpro.
Old August 11th, 2007, 05:24 PM   #8
Ebs
Going to a high pinion differential gets you reverse cut gears...it's kinda a package deal.
Old August 11th, 2007, 11:23 PM   #9
Right, in rear applications, low pinion is stronger. The whole reason they went to high pinions up front is for strength, not for clearance.
For example, just about no one runs a high pinion dana 60 rear because they break.
Old August 11th, 2007, 11:32 PM   #10
Mud'N'Truck
Gotsa. High pinion front, low rear. So do you need different gears to do a high pinion front or just flip the 3rd member?
Old August 12th, 2007, 10:07 AM   #11
different gears. Its mechanically possible to flip the diff(with some grinding to the housing), but its still driving the wrong side of the gears, and it'll be makign you go backwards..
Page generated in 0.17027 seconds with 56 queries
