1% prez........"the jiggler" - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 18th, 2009, 09:22 AM   #161
liv2mx
i like jungle gym's.
liv2mx's Avatar
Originally Posted by silverxj View Post
btw, I heart superior shafts.
i actually ordered 10 factory. but my buddy chris hooked me up with superiors for the same price. they are a piece of art work.
finally finished the front last night. all new bearings seals and shafts.running drive flanges for wheelin.they sure are nice to install.
building a new traction bar and putting the flat skid on. then off to the badlands for some abuse.
Old June 18th, 2009, 09:25 AM   #162
liv2mx
liv2mx's Avatar
Originally Posted by Tab View Post
My Atlas is as quiet as my stock one was an 6.3 million times quieter than my tera low.
i called advanced adapters and they did say they have changed some stuff to make them quiet. it's not out of the question. just finding the rubi cases for alot less then a atlas.
that is good to know that yours is quiet. you just got it not too long ago didnt you?that is usually when they are the loudest is new.
Old June 18th, 2009, 09:33 AM   #163
liv2mx
liv2mx's Avatar
Originally Posted by 95geo View Post
he shouldnt have blown any joints out unless they got loose and did nothing about it, got a bad batch or something is binding up. on the flip side, if there is not much vertical seperation at the axle end then the forces going into the links can be a lot higher, not sure if that could be something or not? I havent seen a heim joint last longer than any generic "flex joint" and the same goes for the opposite. the both last a long time when used and maintained properly.
you dont need bypasses, it's just $500 per corner and more crap to try and package. remote reservoir 2.5's will be all you need. add in the air bumps and you can do everything.
nice excuse if I thought you could hear some t-case gear noise over the rest of your jeep I might believe you.
johnnyj and koz both said when we built his the rear upper joints will fail..they were 100% correct.they are just too small. all of his have failed. he has tightened them alot.he takes good care of his jeep so i dont think it is from lack of effort. heims seem to take the weather better then joints.i have johnny joints in my front lowers.no issues for 2 years. but i have heims in my upper and all my steering, they are also in good shape.
Old June 18th, 2009, 09:55 AM   #164
Tab
Tab's Avatar
yes, mine was new about two months ago. All I know is I don't notice it at all noise wise but the tera low was quite loud. If you can find a rubicon case that would save you some coin but it still has the same size chain and front output right? I just figured I would get the Atlas and never have to deal with tcase issues again for the life of the Jeep.
Old June 18th, 2009, 10:17 AM   #165
liv2mx
liv2mx's Avatar
rubi case has 32 spline outputs front and rear, has the bigger chain, 1330 yokes,alot more beef around the case.i think it is the best bolt in case for the money.i can get them for 900 with a year warranty.200 to 600 in junk yards.make sure anybody that is looking for one does not get a jk rubi case for a tj. the speedo does not work and will throw a code in tj's.
Old June 18th, 2009, 10:21 AM   #166
silverxj
Recovering XJ owner
silverxj's Avatar
you had better knock on wood with your luck in tcases...
Old June 29th, 2009, 09:13 PM   #167
raginranger
xj owner 2
raginranger's Avatar
Thumbs up Some Pics of Liv2mx's fine suspension work
ID:	45605   Click image for larger version
raginranger is offline   Reply With Quote
Old October 19th, 2010, 10:57 AM   #168
liv2mx
liv2mx's Avatar
well time for me to add some upgrades again...
last friday before the race i found my passenger side knuckle was cracked on my 60. so jimmy from extreme hooked me up with a new billet one and a keyed high steer arm.man these are sweet!!
after last weekends beat down. it is also going in the garage after we get back from windrock in a couple weeks.
the plan is to keep it real low, so cutting the hood and the front part of the frame.link the rear. run all inch and 1/4 joints with all alum links.coilovers, bypasses and air bumps..so stay tuned for my never ending nights in the garage...
this is what it looks like now...
ID:	69278   Click image for larger version
Name:	rock crawl tour stop 3 at TT 006.jpg
ID:	69284   Click image for larger version
Name:	rock crawl tour stop 3 at TT 030.jpg
ID:	69285   Click image for larger version
Name:	rock crawl tour stop 3 at TT 026.jpg
Old October 19th, 2010, 11:02 AM   #169
liv2mx
liv2mx's Avatar
someday i will be rocking one like this!!!
ID:	69279   Click image for larger version
Old October 19th, 2010, 11:07 AM   #170
liv2mx
liv2mx's Avatar
and for anybody that don't know this is what mikes rig looks like now.
ID:	69281   Click image for larger version
Name:	rock crawl tour stop 3 at TT 019.jpg
Old October 19th, 2010, 11:20 AM   #171
Why alum links? All the hotshots are running chromo links now and the price is pretty much the same.
Old October 19th, 2010, 11:21 AM   #172
liv2mx
liv2mx's Avatar
sick of seeing them bent.
Old October 20th, 2010, 09:07 AM   #173
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
The second pic is nuts!!!!
Old October 20th, 2010, 06:36 PM   #174
drew91xj
drew91xj's Avatar
rebuild should be sweet cant wait to see it done
Old October 20th, 2010, 08:55 PM   #175
roger
roger's Avatar
Send a message via AIM to roger Send a message via Yahoo to roger
HEY WHO ALL GOING TO WINdROCK sorry for caps
roger is offline   Reply With Quote
Old October 22nd, 2010, 09:07 AM   #176
liv2mx
liv2mx's Avatar
wanna go? leaving thursday nov 11th, coming home sunday the 14th.
Old October 22nd, 2010, 09:19 AM   #177
liv2mx
liv2mx's Avatar
so what should i get? thinking about trying the king 2.5 air shock with the bypass on it.or foa coilovers with there bypasses.or maybe radflo coilovers.i like the idea of the bypass and air shock all in one.i know shannon campbell has run these.they are 800 a piece though.almost pulled the trigger and bought 2 sdi's until i talked to kirby on pirate about them.
foa is the cheapest but not sure on quality.
ID:	69432   Click image for larger version
ID:	69433   Click image for larger version
ID:	69434   Click image for larger version
Old October 22nd, 2010, 09:50 AM   #178
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
kings
Old October 22nd, 2010, 09:52 AM   #179
liv2mx
liv2mx's Avatar
Originally Posted by hosejockey4506 View Post
kings
how does my old ones work?
Old October 22nd, 2010, 09:56 AM   #180
hosejockey4506
Visiting Admin
they are currently on nature boy nates xj for mock up. The fit and finish over the foa's was a huge deciding factor to me, foa's may work but they sure look like crap and if the machining inside looks any thing like the out side i would be scared.
nature boy had issues with his bumps from them also where they were getting stuck pushed in and wouldnt return.
Tags
this shit done yet?
Page generated in 0.53812 seconds with 84 queries
