1% prez........"the jiggler" - Page 76 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 28th, 2013, 04:05 PM   #1501
Grassman
2jz specialist
Grassman's Avatar
Originally Posted by JohnnyJ View Post
You crossed the streams.
looking forward to taking this out of context
Old February 28th, 2013, 04:27 PM   #1502
Originally Posted by liv2mx View Post
what cam duration and loab did you do brandon. i have a couple different suggestions on this.not sure what one i want. the ls6 cam is real mild and i have been told to bump it up a little more if im doing this. yellow springs or orange? did you do the l92 heads? you stay with the truck intake or did you do the car? i am leaning towards the car just because i can drop the engine gaurd more and give me a bunch more visibility in my buggy. they claimed a 10% loss in tourque with the car intake.
LQ4 bottom end, LS3(l92 with diff valves) cylinder heads/intake/injectors, Edelbrock 90mm Throttle Body(DBC), Patriot extreme springs, EPS 222/230 on 112, lift .600ish.
Don't put a cam designed for a cathedral port head(ls6) in an engine with square port heads(L92). You need to look into a torque cam designed to work with square port heads (L92/LS3). Without dyno number I won't comment on the torque numbers but 10% loss seems pretty high. I think either intake will be fine but the truck intake has longer runners IRRC. Better get the cam right, none of the rest of the parts will matter if you don't get that part correct.
Intake info to look at, basically says it doesn't matter L92 vs LS3.
http://ls1tech.com/forums/generation...s3-intake.html
You'll find people out there with much more knowledge than me on this, I only know what I've read and what I've scanned on my own.
Old February 28th, 2013, 05:15 PM   #1503
bbaXJ
Yooper In Training
bbaXJ's Avatar
Erin, whichever style intake you use just don't go with your stock one, you need the new style because you'll no longer have the cathedral port heads to match the cathedral port intake. I seriously doubt you'll lose any power with the car style intake, it'll just move it higher in the RPM range. Not ideal for a crawler, but probably a non-issue for your style of driving. Run what fits your packaging and budget.
You won't necessarily make more power with bigger injectors because engines tend to make more power running a little lean. So you'll be making plenty of hp right until you blow a hole in a piston....sound worth it to you? Get the right injectors, optimize your AFR, and keep yourself from having to do this again next year. We all know you're not easy on stuff, so might as well build it for reliability from the get-go.
Old February 28th, 2013, 05:43 PM   #1504
liv2mx
i like jungle gym's.
liv2mx's Avatar
Yea I know I have to switch the intake.I'm leaning towards the ls3 car one just so I can lower my engine guard so I can see more.also they look so much cleaner on the motor.I wanna do it right.b&d told me to take it and put on a dyno for the best tune.mail order is not the best and he was strait with me on that.so I'm going to take it to muskeg an and do it right. Looking forward to this.
Old February 28th, 2013, 05:59 PM   #1505
Have Baker Eng spec you a cam if they are going to be tuning it..........
Old March 1st, 2013, 06:53 PM   #1506
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Sell me ur old Tcase
Old March 1st, 2013, 08:00 PM   #1507
liv2mx
liv2mx's Avatar
Originally Posted by mr. Beefy View Post
sell me ur old tcase
k..
Old March 7th, 2013, 06:37 PM   #1508
liv2mx
liv2mx's Avatar
so rcv's coming and new rubber....will have some superior 35 spline stuff for sale for a 78,79 ford dana 60.
Old March 7th, 2013, 06:48 PM   #1509
Grassman
2jz specialist
Grassman's Avatar
Give Me A Heads Up On The 60 stuff
Old March 7th, 2013, 07:00 PM   #1510
liv2mx
liv2mx's Avatar
i just did.. they will be available in april. lifetime warranty 35 spline superior inner and outer shafts.spicer non greasable joints also.
Old March 7th, 2013, 07:44 PM   #1511
They don't have a lifetime warranty with spicer joints in them
Old March 7th, 2013, 07:48 PM   #1512
chevotass
chevotass's Avatar
are those claws? what is it with you guys and baja claws
Old March 7th, 2013, 07:55 PM   #1513
Grassman
2jz specialist
Grassman's Avatar
Ok, Let Me Know When They Are Out
Old March 7th, 2013, 07:57 PM   #1514
crosseyed cat
safety cone killer !!!
crosseyed cat's Avatar
NO KIDDING !!! everyone should run BOGGERS
crosseyed cat is offline   Reply With Quote
Old March 7th, 2013, 08:07 PM   #1515
liv2mx
liv2mx's Avatar
the joint does not matter, the shafts have a no question's asked warranty.i asked before i bought them.
Old March 7th, 2013, 08:27 PM   #1516
Lousypirate
Whoop Whoop
Lousypirate's Avatar
46's?
Old March 7th, 2013, 08:32 PM   #1517
You were lied to
Product Warranty Effective on all sales after January 1 st 2008
EVOLUTION SERIES AXLES Evolution series axle shafts are covered by a lifetime warranty against manufacture defects. This warranty does not cover bent axle shafts or shafts that have been modified in any way.
FRONT AXLES Front axle shafts are covered in the respective categories above with one minor exception. SUPERIOR will consider warranty of front axles with broken u-joint ears, as long as the supplied Dana Spicer 5-760 u-joint or better* is used and u-joint is installed using the supplied full circle snap rings.
*Acceptable replacement u-joints are Dana Spicer 5-760X, CTM, Ballistic Joint & Longfield Super Joint
It doesn't really matter though, if you didn't break them, Randy's 4 squirrels never will
Old March 7th, 2013, 08:46 PM   #1518
liv2mx
liv2mx's Avatar
i have spicer joints in there.it says they are covered. it does not matter brandon.were i bought them i can always get them warrantied. and they are tuff.so no worries.
Old March 7th, 2013, 09:41 PM   #1519
bluminade
Bluminade Has Arrived
bluminade's Avatar
claws WTF are u joking? i hope you are
bluminade is offline   Reply With Quote
Old March 7th, 2013, 09:55 PM   #1520
liv2mx
liv2mx's Avatar
Can't pass it up.I'm looking for some sticky 42' s also. I won't be going without enough tires this year. The46 on those wheels are lighter then a 43sx on a steel wheel. We weighed both.it was like 17 PDS lighter each one.so over 60 PDS lighter.
Tags
this shit done yet?
Page generated in 0.34242 seconds with 84 queries
