1% prez........"the jiggler" - Page 62 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 31st, 2012, 11:42 AM   #1221
liv2mx
i like jungle gym's.
liv2mx's Avatar
yea tighten the bolt's... yes i have a new bearing and seal so after a year of it leaking it is replaced.
Old July 31st, 2012, 11:44 AM   #1222
liv2mx
liv2mx's Avatar
looks like i will own a set of 44's for spares..vulcanizing was $250.00 a tire.
Old July 31st, 2012, 11:47 AM   #1223
hamsmotorsports
hamsmotorsports's Avatar
Originally Posted by liv2mx View Post
ok. were is your rig tvjunkie?
hamsmotorsports is offline   Reply With Quote
Old July 31st, 2012, 11:50 AM   #1224
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Ouch
Old July 31st, 2012, 12:04 PM   #1225
Holy shit batman.
Old July 31st, 2012, 12:05 PM   #1226
Did you find exactly what broke then?
Old July 31st, 2012, 12:09 PM   #1227
liv2mx
liv2mx's Avatar
the coupler between the tcase and tranny.stripped the tranny side.
Old July 31st, 2012, 12:11 PM   #1228
liv2mx
liv2mx's Avatar
getting rid of that completely.since it was a dodge 23 spline male to male.going to the 32 spline female to the 465 32 spline male and getting rid of the coupler all together.
Old July 31st, 2012, 12:13 PM   #1229
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
465 sounds like a good plan. With the way it's geared, you could either launch in 2nd in Low, or hit it in 1st in high and have similar gearing on the gears all the way up.
Gear Crawl Hi/Lo
1st 26.86 / 53.71
2nd 14.68 / 29.36
3rd 6.44 / 12.87
4th 4.10 / 8.20
Old July 31st, 2012, 12:30 PM   #1230
4Bangler
Jackstand Wheeler
4Bangler's Avatar
SM465 is a great trans and you won't break it, but it shifts like a bread truck, pick a gear and stay in it.
Old July 31st, 2012, 01:05 PM   #1231
Go automatic. Put it in gear and hold on.
Old July 31st, 2012, 03:07 PM   #1232
dreezy
Haggard Fab
dreezy's Avatar
That's so 2%
Old July 31st, 2012, 07:34 PM   #1233
liv2mx
liv2mx's Avatar
i would of rolled it 4 or 5 times at the badlands with a auto..i will always have a stick in this rig.
Old July 31st, 2012, 07:38 PM   #1234
liv2mx
liv2mx's Avatar
Gear Crawl Hi/Lo
1st 26.86 / 53.71
2nd 14.68 / 29.36
3rd 6.44 / 12.87
4th 4.10 / 8.20
thats what i was thinking after looking at both of the ratio's. this is what i have for specs on the later 465.
couple people have told me i would like the 4500 better but i dont see the benafit in it.2nd is too hi and first is not really low enough.only thing i am worried about is if the 465 will shift good enough for me.1st is not synchronized but 2nd through 4th is. 2nd is the gear i am looking for most use. and like you said john i could shift into hi and use first for more technical hills i think.
Old July 31st, 2012, 07:41 PM   #1235
deerebowtie
Unchained
deerebowtie's Avatar
if you can find one cheap enough, check out a 1995+ nv4500 for better shifting and gearing options. a zf-6 would be killer, but they're kind of hard to find cheap.
Old July 31st, 2012, 07:50 PM   #1236
liv2mx
liv2mx's Avatar
i can do a 95 plus chevy 4500 or the later 465.big price difference between them.but i have to decide asap.they are both available to me.
Old July 31st, 2012, 07:53 PM   #1237
liv2mx
liv2mx's Avatar
the 4500 is 20 pounds heavier,a few inches longer and the stick out put is way in the front on the 4500 compared to the 465.the 4500 also has a aluminum center piece were the 465 is all cast. those few things and the 600 dollar price difference are making me lean towards the 4 speed.
Old July 31st, 2012, 10:52 PM   #1238
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Even though it is sycronized you are not gonna shift the 465 quickly or easily...it just is not gonna happen. A friend of mine is running a all 32 spline 465/203/205 setup behind a very healthy stroked small block in his s10 and its tough aa hell but not pleasant to drive at all. Also keep in mind the shifter throw is huge (i dont know how much room you have) and you really dont dare shorten it up because of the efforr required to shift. The nv4500 in my dodge on the other hand is very nice, it's easy to operate, shifts very smooth with little effort...personally it would be worth the 600$ to go that route...its that much nicer.
Old July 31st, 2012, 11:15 PM   #1239
BigTony
Rock Rebel
BigTony's Avatar
I think you will like the 465 until you attempt to drag race someone. Welding my shifter up and making it 5" inches shorter helped with the long throw and bread truck feel.
BigTony is offline   Reply With Quote
Old August 1st, 2012, 09:05 PM   #1240
liv2mx
liv2mx's Avatar
looks like 465 for now. the 4500 i had on line was the earlier one.
Tags
this shit done yet?
Page generated in 0.39051 seconds with 84 queries
