1% prez........"the jiggler" - Page 53 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 29th, 2012, 07:35 AM   #1041
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I didn't feel like uploading 2 video's
Old May 29th, 2012, 07:54 AM   #1042
Originally Posted by High Center Hancho View Post
99% of that video sucked ass...only the last four seconds was worth watching...WTF???
True.
Old May 29th, 2012, 07:56 AM   #1043
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Then you show up next time and make your own video
Old May 29th, 2012, 09:14 AM   #1044
I don't need to drive all the way to Drummond Island to park on someone's tires.
Old May 29th, 2012, 09:25 AM   #1045
Grassman
2jz specialist
Grassman's Avatar
Burn
Old May 29th, 2012, 09:31 AM   #1046
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Honestly that's all that happened on my trip there. I left Saturday night I guess the good stuff happened Sunday.
Old May 29th, 2012, 10:53 AM   #1047
Porter
Porter's Avatar
Default Hmmmmmm
Looks good Brian/Erin
Drummond was dry as fukc last weekend. Two years ago we had snow, this year it's 80......wtf
Dirty Minds Jeep Club
DMJC WEBSITE
Originally Posted by Twilight View Post
so yeah what Ross said...
Porter is offline   Reply With Quote
Old June 1st, 2012, 09:50 AM   #1048
liv2mx
i like jungle gym's.
liv2mx's Avatar
well i picked up a good t case finally.bought a dodge 205 and flipping it.will also make it a twin stick.this has been a long decision figuring out a tuff case that will work.was ready to buy an atlas and did some research and found i can flip the dodge 205 and it will bolt right up.it's out of a 90 dodge 1 ton.32 spline outputs and nothing but beef.has a 1410 yoke on the rear and a 1350 flange for the front,thanks kevin for hooking me up.now i need to brace it real good and get the new d shafts built,put my bumps on,mount shawns 43"s and head south...
yes my 42's are for sale, i have 5 of them with a new set of inner air locks and 4 20" rims.will be posted in the for sale section. going to the 43's.i need the extra cushion of the sidewall for the things we wanna do now.undecided if i want a 17" wheel or do a 16.5 h1 wheel.
Old June 1st, 2012, 11:06 AM   #1049
When is the run down south?
So do I understand it right that you didn't really get much wheeling in on Drummond? Was hoping you could get some practice before going south. But hey, who needs practice? Just point it uphill and peg it.
Old June 1st, 2012, 11:50 AM   #1050
liv2mx
liv2mx's Avatar
2 weeks we leave for alabama. i wheeled for 2 days on drummond. had a great time.broke my stock t case in 3 spots sunday night.broke rim,broke rear shaft,(i cant believe t case held all weekend was broke and jb welded before i went)
have to get my bumps on change the ride height in the back a little get the new case in and a few little things and i will be ready.
i was very happy with it jim.i drove it out of the garage and loaded it on the trailer and went to drummond.got a real good feel of it ,how it steers(witch is awesome!) you guys that said it would not steer good are crazy! no drag eather way and i can be wide open going right and crank it right back left.
motor rips.everything works awesome! real happy with how stable it is.just doing some fine tuning before we go south.adding the beef for a tcase and drive shafts and it should be pretty damn tuff.after i break the nv3550 i will put a chevy nv4500 in it and i think i will have one hell of a tuff driveline.
i cant believe how comfortable it is and how nice it drives.can see everything also.it feels like i am in a razor almost..cant believe i built it actually, because it turned out better then i expected. i ran 2 tanks of gas out at drummond so i did get some good seat time.(my tank is 10 gallons because i did run it dry.)
Old June 1st, 2012, 12:28 PM   #1051
MiNi Beast
MiNi Beast's Avatar
You going to Grey Rock?
Old June 1st, 2012, 12:38 PM   #1052
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
http://www.greatlakes4x4.com/showthr...=southern+boys
samurai2240 is offline   Reply With Quote
Old June 1st, 2012, 02:03 PM   #1053
Good to hear and I wish you luck down south.
Now then, here's the question. If you got 2 days of wheeling, why are the only vids posted where you are doing a lame ass tire climb? Where's the good vids?
Old June 1st, 2012, 09:56 PM   #1054
4Bangler
Jackstand Wheeler
4Bangler's Avatar
If you're used to the throttle response of 42's on 20's don't go to 16.5 H1 wheels....WAY too heavy....rotating mass will kill your snappy setup. Stick with a 17"+ aluminum wheel.
Old June 2nd, 2012, 09:06 AM   #1055
liv2mx
liv2mx's Avatar
this is all i got jim.http://youtu.be/L4R2OOcP6bE did a bunch of cruising around and trail riding.
Old June 2nd, 2012, 09:09 AM   #1056
liv2mx
liv2mx's Avatar
i will be running shawns 17" steel wheels and 43's down south. so that will give me a good idea what i want.i want to stick with aluminum if i can.(like you said alot of mass and weight with steel.)definetly will have inner and outer rock rings on whatever i get.
Old June 2nd, 2012, 09:33 AM   #1057
My aluminum wheels are heavier than my steel wheels. Check weight before you rush into assuming that just because it's aluminum that it is lighter.
Old June 6th, 2012, 08:53 PM   #1058
liv2mx
liv2mx's Avatar
back home.tcase will be in and my good driveshafts done this weekend.changing my air cleaner setup to a bigger one,getting my bumps on and a little more setup on the suspension. doing some other little stuff before next week.then off to alabama we go! i will have the 43's on it this weekend so i will take a updated picture.
Old June 6th, 2012, 10:20 PM   #1059
kmanxj5011
kmanxj5011's Avatar
Looking good Erin! I want a ride now!
kmanxj5011 is offline   Reply With Quote
Old June 7th, 2012, 02:01 PM   #1060
4Bangler
Jackstand Wheeler
4Bangler's Avatar
This too....but he was talking about 16.5 H1 wheels, and I don't think there is any aluminum wheel out there with less than 10 lug holes that is heavier than an 16.5 H1 wheel.....16/35-16.5" Boggers on recentered H1's with cut down mags and rock rings weigh 180lbs each!!
Tags
this shit done yet?
Page generated in 0.42030 seconds with 84 queries
