1% prez........"the jiggler" - Page 20 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 3rd, 2011, 12:12 PM   #381
Originally Posted by liv2mx View Post
after a bunch more research i think my order will be canceled for the billet flywheel. looks like i can use the parts from a 4.8..have most of the numbers from guys on pirate..we shall see how this turns out.
JB weld for any modifications.
Originally Posted by NitzPixs View Post
Glad to hear you are keeping the Stick... Everyone always seems to take the easy route and go auto..
Hey Brian........
You gonna bring that POS out the Mounds next weekend to show us auto guys how it's done?
Old September 5th, 2011, 09:03 PM   #382
littletrucker
I'd hit that
littletrucker's Avatar
you can do it
Old September 6th, 2011, 09:47 PM   #383
fabricator
throttle jockey
fabricator's Avatar
i have a complete chevy nv4500 setup, if you want to keep a manual trans? 6.5 to 1 first gear and no engine adapters required. you can get a 32 spine input for your 231 or run a doubler.
fabricator is offline   Reply With Quote
Old September 7th, 2011, 08:19 AM   #384
joescamaro67
joescamaro67's Avatar
What year 5.3 are you going with? Throttle by wire or cable? Im thinking of doing the same thing here real shortly?
joescamaro67 is offline   Reply With Quote
Old September 7th, 2011, 07:40 PM   #385
boggin-machine
boggin-machine's Avatar
drive by wire becky
Old September 7th, 2011, 07:59 PM   #386
boggin-machine
hmmm i need to find me one for the jeeper down the road. wasnt sure what model is he looking for?
Old September 7th, 2011, 08:11 PM   #387
My 2003 is DBW but it came from an Escalade so that may make a difference.
Old September 8th, 2011, 06:40 AM   #388
My 02 Denali 6.0 was DBW before I converted it fwiw.
Old September 8th, 2011, 06:53 AM   #389
chevotass
chevotass's Avatar
my o3 6.0 is dbw. and the 04 5.3 i had that erin or joescamaro should of bought when it was for sale was also dbw and it was from a truck. I like my dbw. if you want cable look for a van motor. I looked at a 05 van and it had the 6.0 with cable throttle.
Old September 8th, 2011, 07:44 AM   #390
chevotass
chevotass's Avatar
my guess is it has something to do with it being a van application that the 05 still had cable throttle.
Old September 8th, 2011, 08:09 AM   #391
little_yj_95
little_yj_95's Avatar
Do you guys like drive by cable better than drive by wire? I'm doing a 06 5.3 swap and I'm not sure if I want to change it to dbc.
little_yj_95 is offline   Reply With Quote
Old September 8th, 2011, 09:58 AM   #392
chevotass
chevotass's Avatar
i love my drive by wire so far.
Old September 8th, 2011, 10:08 AM   #393
I've been running my DBW for something like 4 years without a single issue. I see no reason to cobble an existing design to go backwards with technology. Throttle response is instantaneous.
What reason does anyone see to revert back to DBC?
Old September 8th, 2011, 10:38 AM   #394
mschaffer66
mschaffer66's Avatar
Does Erin even need a DBC or DBW? Seems like he could get by with just and on/off switch :)
Old September 8th, 2011, 12:11 PM   #395
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
CHEVYRCKS is offline   Reply With Quote
Old September 8th, 2011, 12:38 PM   #396
Didn't get a pedal with my engine/ecu/yada and needed to buy a bigger TB to go with the intake I chose to run. The IAC and TPS are the same for both TB's so no change there. My PCM supported DBC so there was no cobbling. GM sells the bracket that mounts on the truck intake so changing to a LS1TB that's cable driven doesn't involve any cobbling. I guess I would call bending/cutting/welding the DBW pedal to fit where a perfectly fine DBC pedal is already located cobbling They both have thier failure methods, they're both "instaneous", to each thier own I guess.
Old September 10th, 2011, 08:33 AM   #397
liv2mx
i like jungle gym's.
liv2mx's Avatar
i will be sticking with drive by cable.i run too much water and i dont want to modify my peddle.
so i almost was going to do the nv4500 and 205 from kevin.but after some research it looks like i have to cut the firewall and will not have a flat skid with a 205.so i am sticking with my nv3550.
anybody know for sure what flywheel i need and bellhousing? from what i gather i can use a flywheel from a 4.8 or a 6.0 w those clutch parts.have to get a hydraulic clutch setup to match mine and a early chevy bellhousing. think i have it all figured out.
my super motor guy ronnie is going to go pick me out a motor next week since i am not home during the week right now..i have 4 to choose from 01's and a 02 5.3 all around 10000 miles.(all drive by cable)
Old September 13th, 2011, 09:07 AM   #398
blue_toy
SLOW IS FAST??
blue_toy's Avatar
Hey Erin, is this done yet?
blue_toy is offline   Reply With Quote
Old September 13th, 2011, 04:38 PM   #399
liv2mx
liv2mx's Avatar
i wish...if i ever get home to work on it i might get something done.
Old September 13th, 2011, 04:48 PM   #400
chevotass
chevotass's Avatar
you will take longer than me at this rate.
Tags
this shit done yet?
Page generated in 0.40377 seconds with 84 queries
