tips for using an old trailer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 8th, 2007, 02:06 PM   #1
Gunsworth
Gunsworth's Avatar
Default tips for using an old trailer
Well Im sick of driving the jeep on the highway up-north and I have free access to an 06 350 super-duty and a trailer we use for our New holland skid steer.
Since the trailer is old and rusty and has only seen highway a few times, what kinda things should I go over on it before the pig gig?
Tires are gettin replaced since they are prolly 10 years old and dry-rotted to shit, and brakes seem to work fine, what else should I check?
I figue Ill blast some fresh grease into the bearing buddies and take it for a short hway test since it hasnt seen hway in 5 years
Gunsworth is online now   Reply With Quote
Old August 8th, 2007, 02:25 PM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I'd recommend pulling the hubs and checking them rather than just pushing some grease in there.
JohnnyJ is online now   Reply With Quote
Old August 8th, 2007, 02:36 PM   #3
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
X2, That's where most problems start from.
Old August 8th, 2007, 02:38 PM   #4
bigcountrysg
Countryboy
bigcountrysg's Avatar
x3 on the inspection of the wheelbearings, clean them and then repack them with grease.
bigcountrysg is offline   Reply With Quote
Old August 8th, 2007, 02:42 PM   #5
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Check how bad some of the rust has gotten, like if it has gone through or not. I'd also check the suspension and axle for similar issues.
Old August 8th, 2007, 10:47 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
Do a service on the wheel bearings.. ( clean inspect, repack) adjust all the brakes. Make sure the rust hasn't gotten too structural (crumbling frame rails). and Make sure all your lights are in working order..
Old August 8th, 2007, 11:08 PM   #7
GreaseMonkey
Pew pew!
Good job in adding things that HAVEN'T been posted already...
Old August 8th, 2007, 11:18 PM   #8
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
check that the brake-away works. Check the nuts and bolts on suspension, u-bolts,
Page generated in 0.16234 seconds with 47 queries
