yj bumper - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 7th, 2007, 09:14 PM   #1
ladiekilla04
ladiekilla04's Avatar
Send a message via AIM to ladiekilla04
Default yj bumper
i like sglide's work so i thought i'd post it here, rear bumper he built for me
ladiekilla04 is offline   Reply With Quote
Old August 8th, 2007, 08:31 AM   #2
comanche38
comanche38's Avatar
Holy D-Ring Mounts
comanche38 is offline   Reply With Quote
Old August 9th, 2007, 07:40 AM   #3
greenmeanie
greenmeanie's Avatar
Originally Posted by comanche38 View Post
Holy D-Ring Mounts
my sediments exactly
greenmeanie is offline   Reply With Quote
Old August 9th, 2007, 08:03 PM   #4
sglide
co captain of cubes pants
sglide's Avatar
have you ever seen one snap off and go flying at some one?
i do them this way now so they can be welded on three sides.
but what do i know
i only do it for a living
sglide is offline   Reply With Quote
Old August 10th, 2007, 06:50 AM   #5
comanche38
comanche38's Avatar
If that is what you like, go for it. There is just no need for that much weld. If you have a 3/4" clevis or D-ring you really only need let's say a total of ONE INCH of good, proper weld to carry the same weight, obviously you have to take into account the occasional side pull and such, so it would be more. I figured one inch because the clevis is hardened. I have built many bumpers and worked in the steel business and fabrication for almost all of my working life and the D-Ring mounts that I make are made out of 2 1/2" x 3/4" stock, bevel the welding surface, run a 1/2 weld around it and I have over 3" of weld, well over the required. I do not doubt that you do good work (even though I have not seen any in person) but the ones you saw pull off had other problems - not enough weld, not properly welded or not properly prepped. This just seems overkill and it makes them stand out too much, for my taste.
Old August 10th, 2007, 06:51 AM   #6
ladiekilla04
well i like it
Old August 10th, 2007, 05:59 PM   #7
sglide
sglide's Avatar
when ive seen them fail it was not the weld, but the base metal and placement. they were just welded on the face and under side load ripped the base metal along the heat eff. zone.
yes at a staight pull 3" of 7018 will hold 300,000 (ive done it), but under side load you are banking on the heat eff. zone (right next to the weld) holding.
wich after hydrogen imbritlement is only good for about 4000 draw, and less than 1000 of torque load on 1/4" mild steel.
if i would have used mig, all of these # drop by 40%
by running three sides and useing an open root proc. i know that this bumper will never fail, no matter what.
if some jackass hooks up to him in a mud hole and runs 40 mph to the end of a 100' stap sideways, no one is going to be wareing part of a bumper i built as headgear.
and sence you have been working in the biz for so long you will under stand how qualified i am in this area better than most (or you should at least)
im a pipe welder in the oilfield, when i get called to a job peoples lives depend on me doing it the right way
Old August 10th, 2007, 06:00 PM   #8
sglide
sglide's Avatar
Originally Posted by ladiekilla04 View Post
well i like it
when you get a chance post one up of it on the jeep and painted.
thanks
Old August 10th, 2007, 09:08 PM   #9
ladiekilla04
yeah i just got the last coat on yesterday, the 1" shackles dont fit yet, but ill fix that, i got some 3/4" ones till then, ill try to get the pic tommorow when its not dark out
Old August 11th, 2007, 04:22 PM   #10
ladiekilla04
Here's some pics after i got it herculined
Old August 13th, 2007, 07:34 PM   #11
comanche38
comanche38's Avatar
Old August 14th, 2007, 10:34 AM   #12
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
:chiefwoohaw: :chiefwoohaw: :chiefwoohaw: :chiefwoohaw:
Cellulosic covered electrodes may still be used if care is taken in controlling preheat and interpass temperatures, with pipe wall thickness up to and including 10mm on X-80. It is not currently advisable to attempt to weld on thickness greater than 10mm because increased restraint and cooling rates are expected to increase the risk of weld metal hydrogen cracking. Low hydrogen vertical-up electrodes are not normally used for transmission pipeline production welds, due to the low productivity.
I can search Yahoo for big words too.
:tonka:
Old August 14th, 2007, 09:45 PM   #13
sglide
sglide's Avatar
:tonka:
you dickhead tim:tonka:
you know i cant yahoo or google
Old August 14th, 2007, 10:37 PM   #14
Strangler
Strangler's Avatar
I think it looks retarded, therefore -8 street cred.
Old August 14th, 2007, 10:49 PM   #15
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
hahahahaha
I don't know shit about welding but I trust sglide when he says it'll hold. Might not be the way some would want it to look, but I would pull on it.
Old August 15th, 2007, 08:56 AM   #16
Mongo
Mongo's Avatar
You should weld up a little step stool.:tonka:
Mongo is offline   Reply With Quote
Old August 15th, 2007, 05:44 PM   #17
sglide
sglide's Avatar
Old November 15th, 2007, 12:49 PM   #18
BIG UGLY
your mom likes me best
BIG UGLY's Avatar
i like it would be sweet with spare tire carrier on it
BIG UGLY is offline   Reply With Quote
Old November 15th, 2007, 10:47 PM   #19
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
x2 so is that -16 street cred?
I don't like it but this guy apparently does and it on HIS jeep so nice bumper!! If it works and doesn't break then it's good in my book.
Page generated in 0.61089 seconds with 80 queries
