flatbed trailers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 7th, 2007, 01:09 PM   #1
Lothos
KD8GKB
Lothos's Avatar
Default flatbed trailers
I was curious, is it that much cheaper to make your own trailer than to purchase one from someone other than perhaps a chain store? I'm thinking about a 15-20 footer tandem with brakes. I'm fairly confident in my ability to weld up a deck, but i'm thinking about steel cost right now versus buying a trailer outright.
Old August 7th, 2007, 01:25 PM   #2
Bones
Bones's Avatar
cheaper to buy already built right now
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 7th, 2007, 05:00 PM   #3
And a lot less hassle. If you buy the motorhome it is likely you will have to modify the trailerhitch, add a brake controller and rewire it. Now add 4 weeks of trailer build and it will be mid September before you go on a trip.
Old August 7th, 2007, 05:11 PM   #4
Lothos
KD8GKB
Lothos's Avatar
Oh no, I'm already aiming for 2 weeks to go out. I can flat tow right now without a problem. I'm looking at long haul trips where I want some means of getting a broken jeep home.
Old August 7th, 2007, 07:12 PM   #5
mikecraneguy
CRANES ARE COOL
mikecraneguy's Avatar
where is good place to buy new, if that is better than build??
mikecraneguy is offline   Reply With Quote
Old August 7th, 2007, 07:32 PM   #6
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
i built mine, with the steel from and old trailer home trailer. i got the frame and 2 6000lb axles for two hundred dollars off of a friend. i ended up having about 1300 into it when it was all said and done. its the best pulling trailer i have ever had or used.
gofastbobby is offline   Reply With Quote
Page generated in 0.25006 seconds with 41 queries
