Ford C6 Transmission And Transfer Case - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 7th, 2007, 12:05 PM   #1
traderandy
Default Ford C6 Transmission And Transfer Case
This transmission and transfer case worked great at the time it was removed from the truck. They are out of a 1986 f-350 crew cab. Included is a brand new HUGHES high proformance deep oil pan and installation kit. They have 130,000 miles on them. I will sell these seperatly. I am asking $450 ob best offer. I will sell the transmission transfer case and oil pan seperatly. I am located in white lake, oakland county michigan 48386
Name:	daves trans 005.jpg
ID:	13191   Click image for larger version
Name:	daves trans 002.jpg
traderandy is offline   Reply With Quote
Old August 7th, 2007, 09:11 PM   #2
bigblocked
bigblocked's Avatar
It appears as a 460 bolt pattern. Is that right? Don't know what the diesel pattern looks like. What model T/C is that?
bigblocked is offline   Reply With Quote
Old August 7th, 2007, 11:14 PM   #3
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
How much for the pan seperately?
Old August 7th, 2007, 11:33 PM   #4
traderandy
Hi bigblocked, I may not know how to identify the t/case as good as you, if you like I can send you a better picture so you can. the trans and t/case was bolted to a 351 W If you have any other questions or would like to see it please let me know.
frdtrckmnrich, the pan sells new for about $150 I will sell this new unused pan for $95
Old August 7th, 2007, 11:39 PM   #5
traderandy
Old August 7th, 2007, 11:40 PM   #6
traderandy
Old August 8th, 2007, 12:50 AM   #7
Bronco Sally
Lets go wheelin
Send a message via MSN to Bronco Sally
that looks like a bw1356 t-case just to help u out. Cheers Mike
Bronco Sally is offline   Reply With Quote
Old August 8th, 2007, 12:56 AM   #8
88mudder
In the band!
how much for the trans only? Will it bolt to a 302?
Old August 8th, 2007, 03:43 PM   #9
traderandy
I will sell the transmission for $300 or best offer. The transmission was bolted to a 351 W The information that I have, is that it will bolt to your 302 or any small block.
Old August 8th, 2007, 05:30 PM   #10
Blazin79
Blazin79's Avatar
measurement on the front driveshaft? and u willing sell the front driveshaft?
Blazin79 is offline   Reply With Quote
Old August 12th, 2007, 10:04 PM   #11
traderandy
Default ford C6 trans and transfer case
Hey Blazin79 I will sell the front drive shaft for $35 the measurenent I took is with the shaft collapsed and is from the center of the bearing cup. Drive shaft only 30". measured to the center of the bearing cup including the double yoke 33"
33"
Page generated in 0.25893 seconds with 57 queries
