dana 44 and GM 14 bolt FF axles out of 82 chevy truck - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 6th, 2007, 10:27 PM   #1
d_behan27
Default dana 44 and GM 14 bolt FF axles out of 82 chevy truck
I have for sale a dana 44 front axle and a GM 14 bolt full floater rear axle, both are in good shape and have been painted black. the rear axle has been rebuilt (new wheel bearings, axles seals, cleaned, set backlash, inspected ring and pinion, turned the drums and inspected axle shafts) although it does need brake shoes, brake springs, wheel cylinders, wheel studs and spring perches. I cut the perches off to relocate so it could be put in a jeep but changed my mind. this axle is in good working condition.
The front axle has also been painted but since i decided not to use these in my jeep i never went through so it needs to be rebuilt. I did take th cover off and discovered that the carrier that holds the spyder gears is cracked, this could be replaced or eliminated with a spool or a locker, it will need seals, u-joints and brakes (rotors look like they can be turned), other than that i cannot see anything wrong with it.
I am asking $500 for these but i will accept offers. I am located in Petoskey, Michigan and am willing to drive up to 50 miles if necessary but i will not ship.
If any body has any questions i can be reached at #231-838-3630 and by the way my name is Dan.
Thanks
( sorry the picture isn't very good )Click image for larger version
d_behan27 is offline   Reply With Quote
Old August 9th, 2007, 08:35 AM   #2
BIG AL
GO BIG OR GO HOME!
BIG AL's Avatar
What a good deal
BIG AL is offline   Reply With Quote
Old April 2nd, 2008, 04:01 PM   #3
jkalbin21
jkalbin21's Avatar
I know this is an old thread, but is the 14b still for sale? If so, what gears are in it?
jkalbin21 is offline   Reply With Quote
Old April 2nd, 2008, 08:22 PM   #4
TsCuda
TsCuda's Avatar
His post count sez he hasn't been here in a while.
TsCuda is offline   Reply With Quote
Page generated in 0.17387 seconds with 36 queries
