ranger steering problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 6th, 2007, 06:48 PM   #1
ladiekilla04
ladiekilla04's Avatar
Send a message via AIM to ladiekilla04
Default ranger steering problem
hey my buddy has 2002 ranger fx4 level II and the steering wheel and tires wobble when he goes around turns, checked ball joints and tie rods, seem fine any ideers?
ladiekilla04 is offline   Reply With Quote
Old August 6th, 2007, 07:26 PM   #2
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
like death wobble? or just shake like a bent wheel. kinda hard to bend alcoas
gofastbobby is offline   Reply With Quote
Old August 6th, 2007, 08:06 PM   #3
ladiekilla04
i got some input from sglide, and we think the pump is going
Old August 7th, 2007, 07:28 PM   #4
bikerted86
did you have the front end jacked up to do brakes, If you turn the wheel by the tire on a ford with a rack you will have a wobble when turning for a couple days.
bikerted86 is offline   Reply With Quote
Old August 10th, 2007, 06:50 AM   #5
ladiekilla04
yeah he doesnt think thats it because its been wobbleing for like 2.5 weeks
Old August 10th, 2007, 09:44 AM   #6
bj house
bj house's Avatar
huh plz explain your logic on this comment
Old August 10th, 2007, 06:12 PM   #7
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
By turning the wheels without the engine running you get air in the system and it will cause the wheel to shake a little until it works itself out. They recommend bleeding the power steering system using a vaccum pump.
Old August 10th, 2007, 06:40 PM   #8
sglide
co captain of cubes pants
sglide's Avatar
he left out the part where when his buddy checked the pump there was no fluid in it
sglide is offline   Reply With Quote
Old August 10th, 2007, 07:55 PM   #9
ladiekilla04
yeah but he filled it and it still does it
Old August 11th, 2007, 05:22 AM   #10
sglide
sglide's Avatar
if the pump is messed up due to lack of fluid, filling it wont help.
damage already done
Old August 11th, 2007, 08:49 AM   #11
ladiekilla04
yeah he's getting a new pump anyways
Old August 25th, 2007, 10:29 AM   #12
schneider
schneider's Avatar
I've had some experience with the same problem on an explorer at work... What we found was that the seals in the rack were letting a little bit of air get in and causing the wobble. In our case, the truck didn't lose any fluid yet but it did have the same drivability issue.
schneider is offline   Reply With Quote
Page generated in 0.43100 seconds with 59 queries
