RE Adjustable Track Bar question... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 23rd, 2006, 06:34 PM   #1
mschaffer66
mschaffer66's Avatar
Default RE Adjustable Track Bar question...
So I ordered and installed this track bar for the jeep:
RE1610 Track Bar TJ Front Extreme-Duty - Special design uses Super-Flex joint on one end for max articulation and durability. New design with double bend to clear Dana 44's. More length adjustability than other bars. Must be used with RE1611 bracket. For lifts between 4"-6".
I never ordered bracket RE1611. What is it for? I installed the track bar and to my knowledge I'm not having any problems with it...i haven't wheeled it yet though.
This is the RE1611 bracket
RE1611 Track Bar Drop Bracket TJ Front - Extra H.D. front track bar bracket for TJ Wrangler.
Anyone else running the similar set up? Did you buy the extra bracket?
Thanks
Old February 23rd, 2006, 07:01 PM   #2
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
To mount the Super Flex joint to the frame end. I bolt goes threw the old track bar mount on the frame with a 5/8" bolt and two get drilled straight threw the frame. Without it the track bar is useless. So you couldn't have bought that track bar and have it mounted.
Here's the best pic I have of mine. The RE 1610 is a far better design IMO than the RE1600 peice of crap. I ripped the threads out of mine and the bolt on the frame never would stay thight. I have had no problems out of the 1610 and 1611 combo. Only down size is you might need to cut down the threaded end to allow for Kerry's 4.5" springs.
Old February 23rd, 2006, 07:06 PM   #3
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
hmm i thought you got this one ..
atleast thats what i thought you got :/
nixxerRsixxer is offline   Reply With Quote
Old February 23rd, 2006, 07:15 PM   #4
mschaffer66
Disregard my retardedness...
I didn't know there was a design change on the front track bars.
Damn it Nyxis why did you get me the old piece of shit? :)
haha
Rocky thanks for the pic...I actually had a hard time seeing what I was supposed to see. I've never seen your jeep dirty before...although thats probably more because I never wheel.
Old February 23rd, 2006, 07:16 PM   #5
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
That a rear track bar. :miff:
This is the front junk 1600
Old February 23rd, 2006, 07:18 PM   #6
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
That's cause I power wash all the junk off of it when I dun wheeling. Put WD-40 on the frame and what not helps keep the mud off and makes it look like new.
Old February 23rd, 2006, 07:26 PM   #7
nixxerRsixxer
Homewrecker
junk huh? hmm i put 25k miles on mine never had a problem :/
Old February 23rd, 2006, 08:23 PM   #8
I have that bar.. small amount of wear in that heim joint caused horrific deathwobble on the XJ...
Old February 23rd, 2006, 08:58 PM   #9
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I've heard of alot of people wasting hiems pretty quick on that old design. I've had mine on about 35-40k miles with no problems so far....knock on wood.:miff:
Old February 26th, 2006, 11:49 PM   #10
dune coon
do work
dune coon's Avatar
i used to run the RE 1600 piece of shit too. yes, the heim joint wears out damn quickly, AND I snapped the damn thing right on one of the bends. just flat out broke in half.
dune coon is offline   Reply With Quote
Old February 27th, 2006, 08:32 AM   #11
Can't imagine how that happened... *cough*avatar*cough*
Page generated in 0.21940 seconds with 56 queries
