magnum 727? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 23rd, 2006, 05:24 PM   #1
user name
keep your stick onthe ice
user name's Avatar
Default magnum 727?
I have a 93 ram with a bad trans. I want to put the magnum 318 in my 88 that has a very tired motor and cant seem to get a clear answer on if the 727 will mount to the magnum without ckp interferance. Anyone do this or know someone that has?
Old February 25th, 2006, 12:43 AM   #2
h8pvmnt
Swamp Stomper
h8pvmnt's Avatar
ckp?
The bell housings should be the same as well as mounting points from the flex plate/torque converter. As far as being a direct replacement, not a chance. The computer from the 93 won't work the trans and the computer from the 88 won't work the motor. Of course I'm assuming your 88 is a T.B.I. 318 w/overdrive. Your 93 would be a M.P.I. 318. As far as will they bolt together yes but after that
h8pvmnt is offline   Reply With Quote
Old February 25th, 2006, 04:19 PM   #3
user name
user name's Avatar
it is tbi but its still got the non overdrive 727 the 93 i believe is a stand alone motor only computer with something ealse controling the trans. Not sure if the 727 in my 88 has a elecrtonic lock up and the trucks are both 4 hours away right now.
Old March 9th, 2006, 09:57 AM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
the 727 in your 88 is locked up hydraulicly.
Old March 9th, 2006, 09:00 PM   #5
user name
user name's Avatar
I believe it is the original trany is there any easy way for me to tell if it's a lock up?
Old March 10th, 2006, 08:57 AM   #6
KILLER"B"468
Yankabilly
pull the pan and see if it has an aux mini valve body added to the old one with a 5/16's aluminum line run to it.
Old March 14th, 2006, 07:44 PM   #7
user name
user name's Avatar
so in any event is seams as though this sould work with me posibly tying some trans controls from the 93 harnes up out of the way? I would like to do this a a weekend wile im home from school and even though I have another car to drive i would prefer no surprises. thanks
Page generated in 0.39384 seconds with 44 queries
