Dodge vs Ford - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 29th, 2007, 11:19 AM   #21
barry1me
Just another day
barry1me's Avatar
Originally Posted by bigcountrysg View Post
Buy an older diesel, In my 2002 F-250 I get 22-21 mpg, while towing I get nothing less then 16mpg. In my opinion get the 7.3L powerstroke or the 24V cummins in a dodge you will be much happier.
yeah I would prolly agree with that. Or the duramax is pretty good too. My brother bought one new in 01 has 180K on it now and the only thing he has done is batteries and alternator. He also has been running a super chip since about 40k miles. My next diesel will be a duramax!
barry1me is offline   Reply With Quote
Old August 29th, 2007, 11:28 AM   #22
astrogiblet
astrogiblet's Avatar
At 70mph on the freeway we get 18mpg in our 2003 Dodge Diesel.
At 80 it goes down to 13mpg.
Pulling our 35 foot fifth wheel trailer with a custom made extension out the back with 12" I-beams and a 6000w diesel generator on it and a 75 gallon semi truck diesel tank, we get around 12mpg.
-Brandon
astrogiblet is offline   Reply With Quote
Old August 30th, 2007, 05:35 PM   #23
rockrat
rockrat's Avatar
My next rig will be a Dodge, after all "I'd rather be Cummin' than Strokin""
rockrat is offline   Reply With Quote
Old August 30th, 2007, 06:28 PM   #24
Newride
Newride's Avatar
Get a Duramax ! My buddy tows his 5th wheel on vacation wit h2 other families , one has a ford the other a dodge . He says he getting nearly 20 mpg and leaving the others behind . He said when they were going thru Tenn all he saw was the other two rigs and black smoke behind them LOL. But if you are going to get a new diesel get a 07 classic ! The new one have the new gov regulated exhaust on them that dump raw fuel in them to burn out the cat . After 4 burns at 1200 degrees the exhuast is dead ! And you will be helping me keep my job :-)
Newride is offline   Reply With Quote
Old August 30th, 2007, 08:39 PM   #25
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
He does not get 20 mpg towing a 5th wheel, and WTF are you talking about "After 4 burns at 1200 degrees the exhuast is dead !"
You've been fed lies Newride. The diesel particulate filter (DPF) collects all the "black smoke" and keeps it trapped until regeneration. Diesel is injected at a metered rate to burn off the particulates. This is normal and the emissions systems are warrantied (by a government mandate) for at least 120K miles. A "dead exhaust after 4 burns" is highly unlikely, and if it does happen, it is covered for free.
Stop talking nonsense.
@clarkstoncracker
Old August 30th, 2007, 10:16 PM   #26
Now now..... and remember, that engine goes 1.5 million miles without a tune up, too...
Old August 30th, 2007, 11:19 PM   #27
busyfixin
Balls Deep
busyfixin's Avatar
and dont forget the allison, which is "the same trans they put in big rigs" PFFT yea they gather up all the burnt up ones and put them in a scrap trailer behind a big rig, thats as close as theyll get to a bigrig trans.
Old August 31st, 2007, 07:52 AM   #28
84Scrambler
20mpg towing a 5th wheel is complete bullshit. He either believes his mpg computer or he can't use a calculator. Either way, not a chance in hell of pulling the equivalent of a billboard down the highway sideways is going to result in 20mpg while "leaving the others behind". I doubt he gets much better than 20mpg empty, if that. Show some actual numbers and I'll believe it. Fill the tank to the top of the tube several times and record the useage. Then you can brag about fuel mileage.
Old September 1st, 2007, 05:10 AM   #29
Newride
Newride's Avatar
Well as far as the mpg ... I have no for sure way of telling ... as for the New diesels sucking ... I build 340 of them a freaking night and I know what they do .. And if your an engineer the DPF pipes suck and the threads on them need a pitch change !
Once you hit enough miles there is a burn off on the exhaust .. You are required to run at a consistent speed for 20 minutes, if you fail to do so the burn stops ... you have 3 chances to do this burn off before the computer puts you in a limp home mode and you are required to go to the dealership to have it "fixed" after 3 burn offs the cat is toast ! Thats coming for our engineers at the plant not something I'm pulling out of my ass. Yeah way to go new low sulfur diesel fuel
Old September 1st, 2007, 09:08 AM   #30
84Scrambler
One of the many reasons I like my 2004.5 CTD and B-20 biodiesel. The cat is going to take a trip to the pound very soon as well.
Old September 1st, 2007, 09:16 AM   #31
Bones
Bones's Avatar
huh? Do you build Cummins, Isuzu or internationals? How does building one of you make a systems engineer for all 3?
yeah, thats the shitty Dodge system (like I said earlier in the thread).
The Ford regen process doesn't require that.
If the Dodge cats can't take 3 regen cycles, they're screwed... as will you be.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 1st, 2007, 10:26 AM   #32
toast
i break stuff
toast's Avatar
Default diesels
i've read the threads. seems like there is a lot of pride in what we all drive. personally i have a ford toner and nothing bad to say about it that has not been self induced. i don't sit and boast about what my truck can do and somebody elses cannot. the truth is the powerstroke, duramax, and the cummins are all consumer diesels. i've drivin all of them at length and there are redeeming qualities to all of them. an inline 6 will always produce more usable torque. a v-8 will always be smoother and produce more usable hp. and on and on and on. so the looming threat that dodge is going to loose cummings as a diesel power plant because cummins is a ford owned company......yea that whole thing........well that's gonna through a monkey wrench in the whole program. now ford offers the powerstroke, and the cummins in properly equiped trucks. so is ford gonna be the big dog because they offer two impressive diesels in their trucks? NO! they are the big dog because they also offer a CAT diesel in the same f-series frame. so until we can afford the CAT power we should shut our traps and let the CAT's run the road show. and i'm spent.
toast is offline   Reply With Quote
Old September 1st, 2007, 10:52 AM   #33
Bones
Bones's Avatar
ford doesn't own cummins.
At current production, Duramax is my #1 pick, but I can't afford the new 6.6L
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old September 1st, 2007, 10:53 AM   #34
84Scrambler
I hope you are joking. Ford does not own "Cummings" or even Cummins. Cummins owns Cummins. Ford BUYS Cummins produced diesels to put in their trucks, as does Chrysler.
Old September 1st, 2007, 02:20 PM   #35
toast
i break stuff
toast's Avatar
Default my mis-info
my mistake. i was told some mis-info. but this does not change the fact that you can get a CAT Diesel in a ford f-series which in my very humble opinion and budget would rather have. thanks for the reply without any disdane in the words that you typed thats really nice of you. all i was really trying to say was that any of the three have redeeming qualities but i think that the CAT will spank any one of the others.
Old September 1st, 2007, 02:38 PM   #36
84Scrambler
You have to get what? A F550 or F650 to get a Cat in a Ford? I know up to the F-350, you have the choice of only the Powerstroke. Cummins is still the only diesel offered by the Big 3 in their regular pick-ups that is rated as medium duty. I would love to have a 4500/5500 Dodge with a Cat or even a bigger Cummins. Someday they will get it right.
Old September 1st, 2007, 10:36 PM   #37
Newride
Newride's Avatar
Hate to break it to you but Our Duramax is having the same problems . Don't get me wrong I think that in todays market they are all pretty much great trucks and I'm not tryin to bite the hand that feeds me but before you buy anything compare them all . As of right now { from what I understand }the Duramax has the most power and is the quietest of all three. Good luck in whatever you get !
Old September 1st, 2007, 11:30 PM   #38
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
-Brandon
thats about right on for what my dad was getting in his 03 DRW 3500 hauling 35' travel trailers.. the reports from the chevy / ford guys were single digit MPG's ..
nixxerRsixxer is offline   Reply With Quote
Old September 1st, 2007, 11:44 PM   #39
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
my 320,000 mile 97 powerstroke would get 22mpg to alpena and back religously
Before or after it dropped a valve into a cylinder?
Old September 1st, 2007, 11:45 PM   #40
Hacksaw
Hacksaw's Avatar
I forgot to add, if it says Cummins on the side, It's going to be better :tonka:
Page generated in 1.13243 seconds with 83 queries
