2.9 EFI help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 4th, 2007, 08:05 PM   #1
88mudder
In the band!
Default 2.9 EFI help
88 broncoII with the 2.9 EFI. If i let it sit overnight it will start right up in the morning. The problem is when i shut it off the truck wont start back up and i can smell gas. Sometimes it will start back up after shutting it off. If it does decide to run it misses when i rev it up and when i drive it, it misses really bad. It seems as if its flooding.
Ive already replaced the thermostat, ignition module, wires, cap, rotor, and plugs. Its getting good spark and the fuel pressure is good. The fuel filter was changed last fall. Im starting to run out of ideas on what to try next. Any ideas or experiences?
Old August 4th, 2007, 09:05 PM   #2
88mudder
In the band!
anyone?
Old August 4th, 2007, 09:47 PM   #3
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Was it the 2.8 or the 2.9 that had the rocker problems?
Old August 4th, 2007, 09:52 PM   #4
88mudder
In the band!
think the 2.8 had the rocker problems, not 100% sure on that
Old August 4th, 2007, 10:38 PM   #5
bj house
bj house's Avatar
My VWs had issues with the fuel accumulator (big spring diaphragm that holds pressure after the pump is off) not sure if your Bronc has one but sounds like the same symptoms.
Old August 5th, 2007, 09:34 AM   #6
88mudder
In the band!
thx
Old August 5th, 2007, 09:46 AM   #7
bj house
bj house's Avatar
Look for a schrader valve on the fuel rail somewhere. See if there is fuel pressure there right after you shut it off. Get it going again then let it sit for a couple of hours and check it again to see if there is still pressure. I am sure that there is a more scientific way to check it with a gauge but this might give you a good idea of the residual pressure.
Old August 5th, 2007, 02:19 PM   #8
Quagmire
I can has layinframe
Send a message via Yahoo to Quagmire
2.9's are known to jump timing well at least my old one did alot
Google first.....ask questions later
Actually, the new rule of thumb is you should make your tires bulge slightly more then skooterbuilt when he's wearing his tight ladies pants
Quagmire is offline   Reply With Quote
Old August 5th, 2007, 10:22 PM   #9
offroad86b2
offroad86b2's Avatar
Send a message via AIM to offroad86b2
my brother had a 88 ranger 2.9 that was missing really bad and smelt like gas.we did plugs,wires all that stuff and it ended up being the MAP Sensor
offroad86b2 is offline   Reply With Quote
Old August 5th, 2007, 10:35 PM   #10
88mudder
In the band!
ok ill try that
Old August 6th, 2007, 07:11 AM   #11
88mudder
In the band!
Disconnected the battery for 10 minutes and now its running better. My check engine light went off. The idle is still not coming down after its warmed up and the truck seems to be flooding still.
Here's what ive done so far.
-MAP sensor has been tested and is good.
-Tune up (Cap, Rotor, Wires, Plugs)
-New Ignition Module (has good spark)
-Fuel pressure checked (good pressure)
-IAC removed and cleaned (could still be sticking?)
-Thermostat (truck never had one to begin with)
-Failry new fuel filter installed last fall
Im having all the wires checked because when i pull on the wiring loom the idle will go down and idle rough. It seems as if a wire is shorting out somewhere in the system.
Old August 6th, 2007, 10:42 AM   #12
Never_Evil
Once you get it to run like crap, try to turn the distributor a little each way to see if its a timing issue. Get the ingition coil checked, even if it does "work" it may not be throwing enough voltage. Other possible suspects is your intake gaskets are leaking, heads are warped, bad piston rings.
Old August 6th, 2007, 10:44 AM   #13
88mudder
In the band!
it does have a leak at the oil pan gasket, a few drops on the ground each night. Would that mean anything?
Old August 6th, 2007, 11:24 AM   #14
bj house
bj house's Avatar
mmm no it's a ford :tonka:
Old August 6th, 2007, 01:49 PM   #15
88mudder
In the band!
problem fixed it was the ECT.
Page generated in 0.44288 seconds with 68 queries
