TJ doors in a YJ ?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 9th, 2005, 12:45 PM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default TJ doors in a YJ ??
Will TJ doors work on a YJ with a YJ top ??
Old November 9th, 2005, 01:06 PM   #2
Medic8
You call, we haul.
Medic8's Avatar
Depends, soft or hard top? Soft top? No ah ah. The corners of the doors are square on YJ doors (and the top matches).
Hard top? Not sure. For some reason, I think the doors are different, but I could be wrong.
Old November 9th, 2005, 01:24 PM   #3
ogerdgonz
ogerdgonz's Avatar
Actually depends on half doors or full doors. The TJ doors are the same as the YJ from the belt line down. Actually has several parts that say CJ in the description. The problem is the windshields are different between the two so if you use TJ full doors you would have to cut off the portion around the glass and get that part from a YJ. So you would be better off using YJ doors.
Half doors should work with out a problem and then you could use YJ uppers with the rounded corners or get fiberglass uppers.
ogerdgonz is offline   Reply With Quote
Old November 9th, 2005, 02:01 PM   #4
Tonka
Tonka's Avatar
no, tj doors will not work, the latch mechanism's are different, as are the windshield frame angles.
you could probably make them work, but it would be far easier, and likely cost less to put cj7/cj-8 or yj doors on
Old November 9th, 2005, 02:42 PM   #5
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
x2
Old November 9th, 2005, 02:54 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
ok.. the reason i ask is YJ hard doors seem to have the mirror almost half way back on the door and Tj's have a little farther forward.. when theyre back farther they're harder to see out of IMO
Old November 9th, 2005, 03:09 PM   #7
Tonka
Tonka's Avatar
relocate the arm of the mirror to point forward instead of back. they are supposed to fold, but the aluminum corrodes, and may take some persuasion
Old November 9th, 2005, 04:28 PM   #8
Pongking23
CHOP'S Idol
Pongking23's Avatar
Send a message via AIM to Pongking23
cronk, you can make anything fit with an angle grinder.....or a torch!!!!
Pongking23 is offline   Reply With Quote
Old November 9th, 2005, 04:36 PM   #9
ogerdgonz
ogerdgonz's Avatar
Do you mean the little rally mirrors like on the YJ Sahara or laredos that is mounted by the wing window or do you mean the larger mirror mounted on the hinge?
If it is the larger mirror they are exactly the same I have a TJ mirror on my 88 YJ half doors.
Old November 9th, 2005, 04:49 PM   #10
Pongking23
CHOP'S Idol
Pongking23's Avatar
First buy a YJ and then worry about little $*** like the mirrors..............
Old November 9th, 2005, 10:02 PM   #11
Mclovin
"The Situation"
Mclovin's Avatar
u forgot to mention welder..
Old January 24th, 2010, 06:36 PM   #12
cwwebster
They are close enough. The front angle is different but not enough that it causes a problem. The latch mechanism will need to come over from a TJ also. I did it and it works fine. I would much rather have the newer TJ doors with nicer internal skins. The only challenge is the requirement for liberal use of weatherstripping. If anyone wants I can post pictures.
cwwebster is offline   Reply With Quote
Old January 25th, 2010, 02:33 PM   #13
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
They will fit with a change of the latch.
The windshield angle is an illusion that is done by the frame itself. The doors themselves will interchange.
It is a bolt-on affair. The door frames of the doors are even interchangeable. Just swap out the striker pins.
The pic shows YJ doors on a TJ and vice versa
This is the main page of the article.
Old March 9th, 2010, 04:43 PM   #14
atled
cwwebster -
Did you have to change or adjust the hinges on the door or on the jeep tub?
atled is offline   Reply With Quote
Old March 9th, 2010, 09:02 PM   #15
redmud
10 0011 10101
redmud's Avatar
Search for muddymaki's write up here... he made YJ full doors work just fine on a TJ, and I'm 99% sure that the same could be said for a YJ by moving the door latch. Like someone said above, anything can work with a torch and a grinder....
BDS Suspension
How can you land a space ship on the moon? How can a snake eat an aligator? how does the internet work? some questions are not meant to be answered by man alone.
redmud is offline   Reply With Quote
Old March 9th, 2010, 09:16 PM   #16
awalters
Hired Badass
awalters's Avatar
Why did you answer a thread from five years ago?
awalters is offline   Reply With Quote
Old March 10th, 2010, 11:18 AM   #17
jeepfreak81
81 inches of fun
There was a lot of wrong information in the thread. Why not correct it for someone that may find it in a search?
Old March 14th, 2010, 03:13 PM   #18
jeeptjstud
like me
jeeptjstud is offline   Reply With Quote
Old April 5th, 2010, 02:48 PM   #19
Desert TJ
Formerly cherokee lover
or me
Thanks a lot for the article jeepfreak81
Desert TJ is offline   Reply With Quote
Page generated in 0.40422 seconds with 80 queries
