D30 pinion bearings - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2007, 12:24 PM   #1
Streaver
Streaver's Avatar
Send a message via AIM to Streaver
Default D30 pinion bearings
which way does the rear pinion bearing come out, out the front or the back of the diff housing?
Streaver is offline   Reply With Quote
Old August 3rd, 2007, 12:42 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Out the pinion yoke side.
Old August 3rd, 2007, 12:46 PM   #3
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
ill take it u mean the rear
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old August 3rd, 2007, 12:49 PM   #4
Streaver
Streaver's Avatar
is the pinion seal just pressed in, or is there some sort of retainer that i need to worry about?
Old August 3rd, 2007, 12:50 PM   #5
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
is purple a good answer............just tryin to keep this at the top cause i gotta do it soon
Old August 3rd, 2007, 12:55 PM   #6
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
Old August 3rd, 2007, 12:55 PM   #7
Jeeperz Creeperz
GL 4x4 Vendors
You'll have to pull the yoke off, pull the pinion seal out (just pressed in), then pull the outer pinion bearing (and oil slinger, if equipped).
Why are you pulling it?
Old August 3rd, 2007, 12:56 PM   #8
Jeeperz Creeperz
GL 4x4 Vendors
No, it's not a good answer.
Old August 3rd, 2007, 01:00 PM   #9
Kawierider
Kawierider's Avatar
well about forever ago he toasted his pinion bearing right after he put his new gears in and I think he's just getting around to fixing it.
Old August 3rd, 2007, 01:02 PM   #10
Jeeperz Creeperz
GL 4x4 Vendors
Which pinion bearing did he toast? Or is this just a guessing game where we put a new bearing in with the old race and don't inspect the rest of them and hope that fixes it?
Old August 3rd, 2007, 01:03 PM   #11
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
me too.....me seals are leaking and the trans shop i had my jeep in last said the pinion bearing was shot and they recomend i get it done soon.....that was like in feb......i suxor at life and its not done..............and y don't u like purple......how about orange
Old August 3rd, 2007, 01:04 PM   #12
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
there are multiple pinion bearings????
Old August 3rd, 2007, 01:05 PM   #13
Jeeperz Creeperz
GL 4x4 Vendors
Purple is not a good answer, neither is orange, but as far as colors go they're pretty good guys, I guess.
Old August 3rd, 2007, 01:06 PM   #14
Jeeperz Creeperz
GL 4x4 Vendors
Ummm... yeah.
Old August 3rd, 2007, 01:08 PM   #15
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
Ummm... yeah.
sorry ......like i said i suxor at the life game......not an auto mech....i work on planes.......i can do the work if i have instruction, just don't know stuff in and out like u guys
Old August 3rd, 2007, 01:14 PM   #16
Jeeperz Creeperz
GL 4x4 Vendors
They're not really hard to do, but if you're going to go to the trouble of doing them then do it right. This will involve pulling the front axles and differential to change the pinion bearings AND races. You'll also need a new collapsable spacer (or shims, depending on application).
Old August 3rd, 2007, 01:17 PM   #17
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
my bad he said 30.....i need the rear done.....35 obviously......but would it entail the same thing??.....o and cause im curious how much do u guys charge to do this and how long does it take???
Old August 3rd, 2007, 01:23 PM   #18
Jeeperz Creeperz
GL 4x4 Vendors
Yes, basically the same thing. Be about $230 with parts, tax, and labor. Takes a few hours.
Old August 3rd, 2007, 01:25 PM   #19
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
so thats for the seals bearings races and shims?
Old August 3rd, 2007, 02:02 PM   #20
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
Page generated in 0.47352 seconds with 83 queries
