01 caravan upshift prodlem. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2007, 01:05 PM   #1
user name
keep your stick onthe ice
user name's Avatar
Default 01 caravan upshift prodlem.
I just changed the engine in an 01 dodge caravan with a 3.3L. Normal driviung it runs great shifts nicely. however it will not upshift at WOT it pulls to 4700ish rpm and stops let off it shifts? Im not really sure if this is a lack of power type situation(wont clime to the RPM needed to shift) or a shifting issue. Does anyone know if these have a rev limiter?
Old August 5th, 2007, 07:35 PM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
it's bork
Old August 5th, 2007, 07:53 PM   #3
Freak
Wheelin the HD
Freak's Avatar
thats yooper for its broke... maybe the pump is bad or something is sticking... either way its a minivan
Old August 5th, 2007, 08:10 PM   #4
user name
user name's Avatar
if someone has an 01 caravan can you please go run it hard and tell me what rpm it shifts at when you floor it
Old August 5th, 2007, 08:52 PM   #5
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
thats way too low, should shift somewhere around 5800-6000 rpm
Viperdave is offline   Reply With Quote
Old August 5th, 2007, 11:01 PM   #6
Smiley23
Smiley23's Avatar
Did you set the detent cable right ("Kick Down Cable")?
Smiley23 is offline   Reply With Quote
Old August 6th, 2007, 03:13 PM   #7
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Electronic trans. No kickdown.
Old August 6th, 2007, 03:50 PM   #8
Smiley23
Smiley23's Avatar
So it would be a function of the computer? Or relay on this vehicle?
Eitherway, on a vehicle using a cable kickdown it would require adjustment when experienceing the above problem.
Sorry, I dont know Dodge "options" that well. I do know operations.
Old August 7th, 2007, 08:43 PM   #9
bikerted86
ive had problems with the module having to relearn if you change the trans fluid or disconect lines. Quickest way is to use a scan tool
bikerted86 is offline   Reply With Quote
Old August 7th, 2007, 08:46 PM   #10
Hunter9
Not Right!
Hunter9's Avatar
x2 I would get it hooked up. ALso give it a once over and make sure every plug is plugged in and getting contact. Seems it would throw a code if it was not getting contact but I have seem stranger things...like a minivan that will not shift at WOT....
Hunter9 is offline   Reply With Quote
Old August 8th, 2007, 01:21 PM   #11
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Yes they have a rev limiter.
TPS was my first thought, but now I'm not too sure.
Old August 12th, 2007, 08:54 PM   #12
user name
user name's Avatar
well I finally took it in to the dealership to be hooked to the DRB. as it turns out it thinks its running 60% ethanol(not a e85 station in 400 miles). I will be putting an 02 sensor in some time this week as that is what dodge uses to sense ethanol % in the 3.3 flex fuels. The power and ground lines apear in range so its either the sensor or an issue with the signal wire.
Old August 13th, 2007, 10:19 PM   #13
user name
user name's Avatar
ok I fixed it. If you ever start to have a REALLY rich condition in a 98-03 with no upshift at WOT take it to a dealer and have them check the ethanol % then when it is probly out of range replace you 02 sensor. On second thought just change your 02 sensor every 60,000 miles or so if you have a 98-03 caravan with a 3.3 it plays a HUGE role in the way these vans run.
Page generated in 0.31539 seconds with 62 queries
