Chevy CS series alt wiring - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 23rd, 2006, 10:39 AM   #1
Bones
Bones's Avatar
Default Chevy CS series alt wiring
I have having fits getting my CS series (basically 88-95 TBI motors) alternator to charge correctly.
This is what I have now.
The switch is the 12V ign switch that I run my PCM with.
I have been reading a ton online and there is no soild answer on if I should use the F or I terminal on the alternator (there are 4 terminals).
Anyways, how do you guys have them wired?
The F terminal isn't working of me (stock color pink/black), so tonight I'll try the L (stock color brown)
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 23rd, 2006, 03:41 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
well you should have a THICK red wire that comes off the big pole on the back that goes to the battery + positive.
the brown wire is a tickle wire and goes through the insterment panel and gives an indicator light then it goes to ground. so all you need is a small bulb in line to act as a resistor ,and add a switch to turn it on and off
Yetti
Old February 23rd, 2006, 05:56 PM   #3
Bones
Bones's Avatar
yup, it is just a question as to which pin I run the trickle 12V switch to. But now I have a new problem
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old February 23rd, 2006, 07:01 PM   #4
Yetti
Yetti's Avatar
if your dealing with an alt without a plug then look at the shape of the plug, if its got a large round end then its the spade farthest from it, if I can remember theres 3 different spades.
also the brown wire is power coming from the alt to the dash, not the other way around
Yetti
Page generated in 0.33120 seconds with 35 queries
