ZJ rear axle brackets - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2007, 08:18 AM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default ZJ rear axle brackets
I have been looking for a while for somebody that sells a rear axle bracket set (similar to the ones people buy for swapping a 44 or a 8.8 into a TJ) for a ZJ. Anybody know anybody that makes or sells these?
shawn is online now   Reply With Quote
Old August 3rd, 2007, 09:21 AM   #2
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Shawn, I've never seen any just for a ZJ. I believe people just make the TJ kits work for a ZJ. Or make their own, or cut the stock ones off and reuse them. Sorry I'm not of much help.
Old August 3rd, 2007, 10:54 AM   #3
ajmorell
ajmorell's Avatar
Claytons sells kits specifically for ZJs.
www.claytonsoffroad.com
Old August 3rd, 2007, 12:10 PM   #4
shawn
shawn's Avatar
But, it says you need to run a 4 link set up, so I would have to get the clayton long arm lift
And that link is not correct.
Old August 3rd, 2007, 12:51 PM   #5
Bones
Bones's Avatar
cut em off a stock axle.
4bangler just got done doing this for his 8.8 swap
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 3rd, 2007, 01:52 PM   #6
shawn
shawn's Avatar
Does he have an extra 8.8 with 3.73's?
Old August 3rd, 2007, 01:59 PM   #7
ajmorell
ajmorell's Avatar
Yeah sorry there is no 's'. It is www.claytonoffroad.com. Depending on what you need you could always call and ask Clayton's or call JCR I guarantee they could make you what you want.
Old August 8th, 2007, 01:13 AM   #8
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Since the 8.8 or 44 will have bigger tubes just take careful measurements and cut the brackets off your 35. You will still have plenty of metal left to clean up the brackets and install them.
If you need someone with a plasma cutter to do it, bring your 35 the shop. We will drink beer and cut stuff
JcrOffroad
Zoom Zoom!
Old August 8th, 2007, 07:39 AM   #9
shawn
shawn's Avatar
I have the D44A, and it's getting LOUD! But yeah, I'm thinking just cut off the brackets and put them on the new axle. And since I don't give a crap about the axle housing I am just going to hack the crud out of it. If I had a nother vehicle, I would just bring both axles to you and have them done. But that would be tough to do.
Old August 10th, 2007, 02:18 AM   #10
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
With a small cutoff wheel I am sure you could get to all the welds. If your good with a torch that would work too.
JcrOffroad
Zoom Zoom!
Old August 10th, 2007, 07:26 AM   #11
shawn
shawn's Avatar
Picking up an 8.8 this weekend.
Old February 25th, 2011, 07:22 PM   #12
shawn
shawn's Avatar
So evidentally, someone offers a ZJ Rear Axle Bracket Kit now. This would have been handy a few years ago. I had to cut my brackets off and re-use them.
http://www.ironrockoffroad.com/Merch...Code=IR-ZF88BK
Old February 27th, 2011, 07:58 PM   #13
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
The only difference is the sway bar link brackets.
Old February 27th, 2011, 08:34 PM   #14
shawn
shawn's Avatar
Hmm, it's been a while now, but it sure seemed like there were more differences then just that. I know my abs didn't work anymore, and I was real close to rubbing my tires on the coil buckets, the 8.8 is a little narrower than a stock Jeep rear axle.
Old February 27th, 2011, 08:39 PM   #15
Jeeperz Creeperz
GL 4x4 Vendors
Coil buckets are on the frame. A 32x11.50 tire on a stock rim on a stock axle will rub with weight in the rear. The 8.8 is narrower and you should use spacers (or wheels with less backspacing). As far as axle brackets, the ZJ sway bar and TJ sway bar are the only difference.
Page generated in 0.29890 seconds with 68 queries
