chains oir straps? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 1st, 2007, 04:19 PM   #1
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
Default chains oir straps?
i have always used straps in the past, but am sick of them breaking on me. i just recently started using chains and binders. what do you guys use?
gofastbobby is offline   Reply With Quote
Old August 1st, 2007, 04:29 PM   #2
Straps. Never broke one yet.
There is a theory that you should use chains in the back due to a head on collision that the chains will hold up better. But, it all depends on the type/ size of the chain versus the type/ size of the strap.
It's all about the ratings & how they are utilized.
Old August 1st, 2007, 04:33 PM   #3
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
Chains are for tractors.
Old August 1st, 2007, 05:17 PM   #4
Straps..
The big difference is stretch. Because straps stretch, then if the load moves an inch due to a big bump, it doesn't go slack, it just has less tension. Chains have very very little length change under typical tension, so if the load moves a little, they can go slack. Maybe its only a litle bit, but it doesn't take much for a hook or binder to come undone.
Old August 1st, 2007, 05:27 PM   #5
badazzamc
Get Some
badazzamc's Avatar
I use straps and have never had any problems with them coming loose or breaking.
Old August 1st, 2007, 05:30 PM   #6
Pokerob
hug life
Pokerob's Avatar
strap on
Old August 1st, 2007, 06:03 PM   #7
Smiley23
Smiley23's Avatar
Originally Posted by pokerob View Post
strap on
Strap off
Smiley23 is offline   Reply With Quote
Old August 1st, 2007, 06:03 PM   #8
Smiley23
Smiley23's Avatar
Fun for the whole family!
Old August 2nd, 2007, 04:24 PM   #9
busyfixin
Balls Deep
busyfixin's Avatar
i alway use chains. ive never had a problem. heavy equipment is required to use chain, why should my trucks be different?
Old August 2nd, 2007, 05:14 PM   #10
xj4life
xj4life's Avatar
i've been using straps for 3 years and i've been pretty happy with them.
Old August 2nd, 2007, 07:39 PM   #11
i use two 3" straps up front and a chain and binder on the rear, i also hook a chain loosely in the front as a safety precaution in case the straps fail.........
i want to know do you guys hook to the frame pulling the susp tight to the trailor or do you hook to the axles leaving the susp loose on the truck
Old August 2nd, 2007, 09:33 PM   #12
Axles.
Old August 2nd, 2007, 10:18 PM   #13
Mclovin
"The Situation"
Mclovin's Avatar
Old August 2nd, 2007, 10:37 PM   #14
cvwindows
I think I can make it!!!!
cvwindows's Avatar
Straps on axels.
cvwindows is offline   Reply With Quote
Old August 2nd, 2007, 10:57 PM   #15
4 straps to the axles, one for each corner. Use an axle sling for each strap, so your straps don't wear on the axles. Each strap should be pulling away from the others. That way, each keeps tension on each other strap. Bumps can shift a load, so this arrangement makes sure to keep it tight.
Myself, I feel you can't be too careful. I've never had a problem in 10 years of towing my rigs, but I've seen many failures. Its a very good idea to stop after driving the few 5 miles, to check the tension on all of them (as well as the bearing, brake, and tire temps, especially if the trailer hasn't been used in a while). Then check everything each time you stop.
The only time I've had a load start to get loose, was a Honda CRX, that didn't have easy spots to tie to the suspension, so I tied to the frame shipping hook points. As the body bounces, it loosens the straps. But I caught it on my 5 mile check before it got too loose.
Another note on straps, make sure you click the ratchet handle all the way into the locked position. Some folks aren't aware that there is a lock position on them (clicked all the way closed).
Old August 3rd, 2007, 04:58 PM   #16
gofastbobby
good point about checking the load. it's amazing how much tension you can lose from the load shifting in just a couple miles.
Old August 19th, 2007, 01:36 PM   #17
warthog
warthog's Avatar
My trailer is set up with chains. All four corners, with a racheting tightener system for each...I also stop after the first couple miles to check and re-tighten anything that loosens up. I've heard arguments for hooking to the axles and to the frame, and, with that information, I have chosen to hook to the axles. I've been hauling with this trailer for over six years now, and have never lost a load yet...(knock on wood) I have hauled with other trailers, using chains, straps, or a combination of both. I think it is most important to make sure you check your set up frequently and insure that your equiptment is in servicable condition. Don't use frayed straps or worn chains, and don't drive like a maniac and you shouldn't have any problems!
warthog is offline   Reply With Quote
Old August 19th, 2007, 03:14 PM   #18
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
I use chains and binders in the factory tie down locations for short trips. Check after about a mile or two. Live on a bumpy road so if they are going to loosen up they will do it in that stretch. For long hauls for extra safty I also use a couple of straps one to my front reciever and one to the rear. Never had any isues.
GNJEEPN is offline   Reply With Quote
Old August 29th, 2007, 10:23 AM   #19
bigcountrysg
Countryboy
bigcountrysg's Avatar
Straps and one chain with binder. The chain is for safety if one of the straps gives way the chain will hold the load in place. If for some reason all the straps break the chain will keep the load in place until I can get to a safe place to stop.
bigcountrysg is offline   Reply With Quote
Old August 29th, 2007, 10:31 AM   #20
roll-bar Bob
roll-bar Bob's Avatar
he nailed it !!!
Page generated in 0.50380 seconds with 83 queries
