lockers air,cable,electric - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 1st, 2007, 10:09 AM   #1
milwaukeemud
Default lockers air,cable,electric
Im troubled with what kind of locker to put in my truck I know I need to put a "posi" in the rear diff but the front is a diffrent issue my truck dosnt stt the trail's too much but I would like the traction when needed all the 3 air,cab,ele sound good but im sure they all have there problems any sugestions would be helpful
milwaukeemud is offline   Reply With Quote
Old August 1st, 2007, 10:28 AM   #2
It would help if you mentioned what truck you have, and what axle type you are specifically looking to lock. Not all of those options are available for all axles....
Old August 1st, 2007, 10:41 AM   #3
milwaukeemud
I have a 84' 1/2 ton suburban with a 10 bolt in the reat and a 12 bolt up front dose that help? I know it's stock
Old August 1st, 2007, 10:42 AM   #4
jeeptjpaul
jeeptjpaul's Avatar
I don't think you have a 12 bolt front.
jeeptjpaul is offline   Reply With Quote
Old August 1st, 2007, 11:05 AM   #5
milwaukeemud
well since someone removed all the stickers from the truck I dont know what I have
Old August 1st, 2007, 11:07 AM   #6
jeeptjpaul
jeeptjpaul's Avatar
They are probably both 10 bolts. Just weld it.
Old August 1st, 2007, 11:28 AM   #7
milwaukeemud
sure that would work if I only went streight
Old August 1st, 2007, 11:33 AM   #8
jeeptjpaul
jeeptjpaul's Avatar
Never mind.
Old August 1st, 2007, 11:59 AM   #9
95geo
newbie
95geo's Avatar
detroit
Old August 1st, 2007, 12:10 PM   #10
clarkstoncracker
lol
clarkstoncracker's Avatar
umm.
I can turn, I have a welded front.
I have a detroit in the rear.
Old August 1st, 2007, 12:36 PM   #11
PavementPounder
PavementPounder's Avatar
If the rear is larger than the front, you have a 10-bolt front and a 12-bolt rear. I think we determined that in a previous thread.
If you don't wheel that often and drive mostly on the street, a limited slip is also an option for your front. 10-bolts are the same front & rear and your gear ratio is very common among Chevy trucks. So, you can probably score one used pretty cheap and just rebuild it if necessary.
I wouldn't bother with a front locker in your truck unless you're ready to re-gear also. You should also think about how much money you really want to dump into a 10-bolt front in such a heavy vehicle.
Old August 1st, 2007, 12:43 PM   #12
95geo
newbie
95geo's Avatar
umm.
and that is why you broke the front alxe shaft and you will continue to break them
you can weld a 60 front but a 44 needs some way to take the bind out of the axles.
Old August 1st, 2007, 12:45 PM   #13
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
He had a lunch box when he broke the stock shaft.
JcrOffroad
Zoom Zoom!
Old August 1st, 2007, 12:48 PM   #14
clarkstoncracker
lol
uhh, thats news to me. I know numerous people running welded 44's, even on stock shafts, no issues.
now that I'm sitting on CA shafts, and hardcore u-joints, I'm not worried about anything except for the lockouts.
Old August 1st, 2007, 01:25 PM   #15
Cartman
Can't lose with 42s
Cartman's Avatar
I smell BS 95geo..
If I had a dollar for everytime I've seen a lincoln locked 44 front hold up I'd be a freakin millionaire.
Don't drive like a moron and they last.
Cartman is offline   Reply With Quote
Old August 1st, 2007, 01:41 PM   #16
95geo
newbie
95geo's Avatar
ok, fair enough.
Originally Posted by Cartman View Post
I smell BS 95geo..
what is BS about what im saying?
I have seen many more things hold up than fail, its just how it works. it holds up 10 times and breaks once....
Old August 1st, 2007, 01:43 PM   #17
clarkstoncracker
lol
ok, fair enough.
Well, I've witnessed welded 60's break also. Does that mean that everyone has to run portals?
That logic is so stupid.
Old August 1st, 2007, 01:52 PM   #18
95geo
newbie
95geo's Avatar
a welded dana 44 front breaks because the shafts arent strong enough to be stressed that much without relieving some of it (a locker unlocking). bigger axles can handle it because traction will give before a shaft will.
picture turning a corner then climing an obsticle with the outside tire. the outer tire wants to travel further because it travels in a larger arc than the inner, this causes the front axle to bind up. then start to put power to the tires and this is added to the force that is already put on the alxe shafts from the turn and now your trying to pull the truck with it.
when you understand the logic it isnt stupid.
Old August 1st, 2007, 01:57 PM   #19
clarkstoncracker
lol
Sure.
But you can go through all the axles. How about a 30? You can weld those, and run 35's on them. Some people never break them.
You made a post saying I would constantly break 44 shafts because of a welded locker, and I will disagree with you.
I had prety much the same setup as biohazardbill. We went on a lot of trips. He broke every time, I rarely did.
The difference, driving styles. Even though I always made it where he did, and after he broke, I continued on.
Old August 1st, 2007, 02:02 PM   #20
95geo
newbie
95geo's Avatar
you are correct, I made a post saying YOU will continue to break a dana 44 front axle given that: it is welded, on 37s that have a lot of traction and you have a healthy v8 powering it.
How many more times will you break it before swapping in a 60?
Page generated in 0.40085 seconds with 83 queries
