Starting to upgrade the trail truck.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 30th, 2007, 09:57 PM   #1
Default Starting to upgrade the trail truck....
Decided its time to start dialing it in. Its been running good for the last 1.5 years now. So, starting to fix the things that bug me:
Wanted more stability, so Its getting 3 more inches of axle width, via a new diamond up front, and rear spacers:
More width from bigger tires (38.5 x 14.5 SXs), that'll pick up another ~2" of width..
While I'm at it, the wheels are getting beadlocks, also adding another ~1.5" of width. So the truck will be about 6-7" wider than before..
Also revamping the whole brake setup. Land Cruiser discs with V6 calipers up front, the rear is getting the old front brakes and calipers. I also installed a 1988 Supra 1" disc/disc master, and bigger dual diaphram booster.
Then, for good measure, its getting a new instrument panel, including all new senders for everything. The speedometer is electronic and programmable for correct accuracy.
I'll post pics when its all put back together in a few weeks. Its getting some other crap, too. New 120 amp alternator, new interior wiring/switch panel/cb mounts, hydro steering assist, Thorley header/magnaflow exhaust, and I still have to toss in the comp 252s cam...
Dang, this little pos is getting expensive...
Old July 30th, 2007, 11:43 PM   #2
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Lots of sweet things. VERY jealous. Details on every thing. I want to do most of the things you are doing. Really want to do Gauges. That thing is going to be sweeeeet.
Any chance i can have all that stuff.
Old July 30th, 2007, 11:47 PM   #3
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
would like to point out that im jelous of the cardboard.....i want that in my jeep
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old July 31st, 2007, 10:07 AM   #4
Yep, thats my mockup piece. I brought it to work today to transfer the dimensiosn to the computer and make a full size template. I am probably using a piece of 0.22" thick plexiglass I have for the panel, it will get epoxied in place, then the whole piece will be repainted.
Crappy gages has always been a pet peeve. My goal with this truck is to really have things working cleanly. Those are VDO gages, which since I design instrument clusters/gages for VDO, it was my first choice. They have kits that come with everything but the tach, including all new senders. My kit even came with a new float for the gas tank, and a screw-on VSS to convert the mechanical T-case signal into a pulse train to drive the programmable speedo. I lucked out, found someone sellign the brand new kit on ebay from a project he never finished. So I ended up paying about $150 for $450 worth of gages.
Hopefully I'll make some more progress on the rear discs tonight. I've been waiting for the longer wheel studs to come in, which should be here today.
Old July 31st, 2007, 10:42 AM   #5
95geo
newbie
95geo's Avatar
nice, I like what your doing with the stance.
Old July 31st, 2007, 11:40 AM   #6
Bones
Bones's Avatar
what is your overall WMS to WMS going to be?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 31st, 2007, 02:09 PM   #7
~62" wms-wms front, 61.5" in the back.
rims are 15x~8.75 after the weld on BLs.. with 3.375" BS
With the tires, my excel sheet tells me I should be ~78" outside to ouside, and 49" inside to inside on the tires.
Old July 31st, 2007, 06:02 PM   #8
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
No bookshelf for all your tech manuals and reference materials?
Old July 31st, 2007, 08:08 PM   #9
Just my computer and a magic 8 ball...
Old July 31st, 2007, 09:24 PM   #10
GreaseMonkey
Pew pew!
8 ball....I didn't know Stan rode shotgun with you.
Old August 1st, 2007, 09:08 AM   #11
Rattler
Home Sweet Homicide
Rattler's Avatar
Should be nice when your done.
Old August 3rd, 2007, 10:00 PM   #12
Starting to look a little better. The holes are for the telltales. There will be: Left turn, high beam, right turn, Brake, Check Engine, and Battery/Charge.
I cut all of the telltales from scrap lincoln navigator clusters at work, and am making LED backlighting for them.
Testing the backlighting color options. Eventually, I'll retrofit LEDs in them when I have time..
Old August 4th, 2007, 11:45 AM   #13
88yj
collecting parts
88yj's Avatar
Send a message via AIM to 88yj
Looks pretty good.
88yj is offline   Reply With Quote
Old August 4th, 2007, 11:52 AM   #14
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
I sit at 74" with Toy8 2" Spacers 15x8's and 38x12.5s ..
nixxerRsixxer is offline   Reply With Quote
Old August 5th, 2007, 06:55 AM   #15
gonepostal
gonepostal's Avatar
here are those pics of the tubing clamp that I had my buddy make for the hydro assist.
gonepostal is offline   Reply With Quote
Old August 6th, 2007, 12:15 PM   #16
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Looks good.
Since it looks like I will be keeping my 4runner I am gonna try to do something similar.......only in the rear I think I am gonna usethe stock 8.4 I pulled from my Tacoma........should give me the extra width and a little more strength to boot :)
Old August 6th, 2007, 01:46 PM   #17
95geo
newbie
95geo's Avatar
you can make one of those that is 1/2 the weight, use 1/2 the wall thickness for the clamp and use a single pinch style clamp with 2-3 bolts on one side with a .125 groove or so for the squish.
Old August 6th, 2007, 02:13 PM   #18
Yeah, thats what I was thinking of, Ive seen several of that stype from Pirate...
Hmm, I have some Sch 40 tube, which has a 1.38 inner diameter. I bet if I slot it big enough, it should suck down into a 1.25 ID cleanly.
Old August 6th, 2007, 02:31 PM   #19
95geo
newbie
95geo's Avatar
you need the surface area, the closer to the diameter the better.... if you want a few inch long piece of 1.75x.25 dom let me know, Im pretty sure I have a few scraps laying around.
Old August 6th, 2007, 02:40 PM   #20
95geo
newbie
95geo's Avatar
how about an actual height on those tires too, curiousity has the best of me....
Page generated in 0.37861 seconds with 83 queries
