gear lube - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 30th, 2007, 08:41 AM   #1
greencj
greencj's Avatar
Default gear lube
Hello, Just wondering if anyone knows if you can break in new gears with synthetic lube. I know your not suppose to, with a new motor but was wondering about gears. Thanks.
greencj is offline   Reply With Quote
Old July 30th, 2007, 09:47 AM   #2
greenmeanie
greenmeanie's Avatar
what axle?? some axles require synthetic only, so you'd obviously need to use synthetic. just got my jeep done last night and started breaking the gears in (8.8 is synth only) i imagine it is fine, just not 100% sure (all knowing axle gurus chime in here....):tonka:
greenmeanie is offline   Reply With Quote
Old July 30th, 2007, 09:52 AM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
just to let ya know thats false. High end cars like ferrari, porsch, BMW, etc... all come fromt the factory with snynthetic oils.
I would just run normal gear lube as if your going to wheel it you'll probably be changing it frequent.
Old July 30th, 2007, 10:41 AM   #4
Cartman
Can't lose with 42s
Cartman's Avatar
agreed.
theres an old saying that transfers to this...change oil hot, change oil frequently.
Relocating your axle breathers should be one of the first things you do to your rig. This will eliminate water from entering the diff...it doesn't matter what kind of oil you got in there, if you mix it with water, it's junk.
my .02
Cartman is offline   Reply With Quote
Old July 30th, 2007, 01:07 PM   #5
greencj
greencj's Avatar
They are dana 44's out of a scout. I mainly only use the jeep at silver lake. Its never been in the water. Mainly just climbing hills and racing. Thanks for the info.
Page generated in 0.22032 seconds with 38 queries
