to add or not to add; that is the question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 27th, 2007, 10:00 AM   #1
greenmeanie
greenmeanie's Avatar
Default to add or not to add; that is the question
putting 4.88's on my detroit locker for my yj dana 30.
the carrier comes out/goes in easily (don't need a pry bar to take it out, or a hammer to get it in)
the gear pattern is perfect, but i am worried that the carrier might need another shim.
should i add .002" to the carrier, so it is a bit more snug; or just call it good after i put new bearings on?? (maybe the new bearings will tighten it up a little)
like i said, the pattern is absolutely perfect, and i don't want to make the pinion mesh any deeper on the ring gear; so if i add, what side should i put the shim on??
will .002" make that much of a difference on the pattern anyway?
i can take a couple of pics tonight or tomorrow if needed.
greenmeanie is offline   Reply With Quote
Old July 27th, 2007, 10:03 AM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Add.
When you press on the new bearings it will become looser than it is now unless you add shims. Add to both sides and it won't change the pattern.
Old July 29th, 2007, 12:04 AM   #3
PavementPounder
PavementPounder's Avatar
Originally Posted by Jeeperz Creeperz View Post
Add.
Yes, add. The recommendation I have been given in the past is .004-.007.
Old July 29th, 2007, 12:37 AM   #4
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Without a case spreader you should have to use a dead blow to get the carrier in, and pry bars to take it out.
If you can slip it in easy I would start at .005, but it may take more.
JcrOffroad
Zoom Zoom!
Old July 29th, 2007, 09:42 AM   #5
greenmeanie
thanks guys. do you mean start @ .004-.007 per side, or total??
Page generated in 0.15480 seconds with 38 queries
