on demand hot water - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 26th, 2007, 06:50 PM   #1
Miffy
Miffy's Avatar
Send a message via Yahoo to Miffy
Default on demand hot water
Ok I know there is one of you guys out there that know about these things.
I am going to get this for my house, who can tell me the best product for the best price out there?
One of the problums in my house right now is my hot water tank is on one end of the house and it takes 3 to 4 min. for it to get to the kitchen at the other end.
Please share...
Miffy is offline   Reply With Quote
Old July 26th, 2007, 06:54 PM   #2
Mongo
Mongo's Avatar
You need to find a man to do this for you.:tonka:
Mongo is offline   Reply With Quote
Old July 26th, 2007, 06:54 PM   #3
Immortal
NO RELIGION WAT!
Immortal's Avatar
bosch. get the biggest one you can afford
Old July 26th, 2007, 06:59 PM   #4
Weifallo
Weifallo's Avatar
We had one of the "instant" hot water things and couldn't get it to work correctly... went back to the good 'ol water heater.
Might have just been a fluke though... not sure.
Weifallo is offline   Reply With Quote
Old July 26th, 2007, 06:59 PM   #5
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
X2
Old July 26th, 2007, 07:00 PM   #6
Weifallo
Weifallo's Avatar
unless you're talking about one of those hot water taps that you put in your sink... those things are great!
Old July 26th, 2007, 07:04 PM   #7
5.9zj
5.9zj's Avatar
I am not a plumber nor know a lot about hot water heaters, but I would have to think that getting an on demand water heater would not solve the 3-4 minute lag for hot water to get from one end of the house to the other. It seems like the hot water tank has hot water available, but it just takes a while it to get there. I would guess the only difference is that the on demand does not store hot water but heats it as it pass thru and the tank you would constantly be storing hot water. I just do not see it helping speed up hot water delivery.
5.9zj is offline   Reply With Quote
Old July 26th, 2007, 07:04 PM   #8
TJ SKWIG
Professional Dumbass
TJ SKWIG's Avatar
i am a hvac installer by trade and i have installed these before, i believe the brand we installed is RINNAI... and you would definately need someone qualified to install one.... but they are sweet! but the guy above me may be correct in saying that it may not solve your problem... there is an alternative though... its kind of like a recirculation pump.... you should probably talk to a plumber about it though... basically it recirculates the hot water throught the pipes when your not using it to keep it hot in the line at all times...
TJ SKWIG is offline   Reply With Quote
Old July 26th, 2007, 07:19 PM   #9
Lothos
KD8GKB
Lothos's Avatar
Dunno what you guys are talking about, but I've seen 2 units installed and they pretty much had a little reservoir like a water fountain for the initial water coming out of the tap and were plenty hot enough to keep it hot after a few seconds. No lag whatsoever.
Old July 26th, 2007, 07:26 PM   #10
Rockstar
sɐƃǝʌ sɐן
Rockstar's Avatar
Don't get it thought Home Depot get it from are real plumbing warehouse or you be sorry
Rockstar is offline   Reply With Quote
Old July 26th, 2007, 07:27 PM   #11
artistic_gore
I own @ halo
artistic_gore's Avatar
Send a message via AIM to artistic_gore
It's not kind of like a re-circ pump, it is a re-circ pump, they work great from what I've seen, it's just a pump that constantly circulates the hot water until it is needed.
artistic_gore is offline   Reply With Quote
Old July 26th, 2007, 07:34 PM   #12
special ed
Pickup Agent
special ed's Avatar
My sister and her husband had two tankless put in their house. They suck. You have to wait at least a minute for warm water in the shower. The dishwasher depends on hot water to operate, it does a shitty job with a tankless. You just need to run a return loop from your furthest fixture, back to the drain valve on your hot water tank. That will solve the lag. There is a thing you can get from the building supply that will make it work a little better. My Dad has one, he likes it. Or you can put a little circulating pump on your return line. If you run your hot supply lines with some "grade" (run them slightly uphill to your fixtures), and grade the return line downhill back to the tank, it will circulate by thermosyphon. I am not a plumber, but I worked as one for two years in Saginaw, and I know every thing about everything.
http://www.rewci.com/whhohotwaci.html
http://www.chilipepperapp.com/tscs.htm
special ed is offline   Reply With Quote
Old July 26th, 2007, 07:39 PM   #13
Chinski
I think there are a couple different types. Some replace your water heater and would go in that location. To solve the lag proble you would need one of the re-circ ones. There is another type that you put right at the sink or shower. This way the source of the hot water is right next to where you are using it so there is no travel time from one end of the house to the other, no lag.
Chinski is offline   Reply With Quote
Old July 26th, 2007, 08:31 PM   #14
tweak
Are we there yet?
tweak's Avatar
These things suck - we have one for our cabin and the water temperature cannot stay consistent... You will be taking a nice warm shower and then bam scolding hot water, or even worse ice cold water.
I would not get one of these units again.
Old July 26th, 2007, 08:43 PM   #15
cjric
cjric's Avatar
the problem is most people dont get one big enough. a normal family needs at least 200K btu. I helped a friend put one in his house and it works fine. Installed easy too.
cjric is offline   Reply With Quote
Old July 26th, 2007, 08:44 PM   #16
Stan
I got a gold chain
Stan's Avatar
Three of the better names, Bosch, Renni (sp), Norits.
My inlaws have a Norits. It has the most output, I think it is 8 gpm. They can run 4 showers and then some at one time.
DO NOT get a Home Depot unit. They work for shit.
Stan is offline   Reply With Quote
Old July 26th, 2007, 08:54 PM   #17
Just to be clear, Sue, do you mean an Instant-hot for the kitchen, or a tankless whole-house water heater?
I'm guessing you want an instant-hot for your kitchen. They are sweet, my parents-in-law swear by theirs, but I don't know what brand it is...
Old July 26th, 2007, 08:55 PM   #18
GerkTJ
GerkTJ's Avatar
We had one when they first came out 20 years ago. Running it on well water sucked big time. Every time the water pressure would drop the burner would turn off. We went back to a regular hot water tank and are happy.
GerkTJ is offline   Reply With Quote
Old July 26th, 2007, 09:04 PM   #19
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
x2 on the rinnai.. ive been in quite a few homes with these and they kick ass.. lots of new homes are being built with these..
nixxerRsixxer is offline   Reply With Quote
Old July 26th, 2007, 09:28 PM   #20
FrankNBrew
Me balls are huge
FrankNBrew's Avatar
One solution is to install one of these under your sink:
http://www.amazon.com/exec/obidos/tg...?v=glance&s=hi
Plumb it into your hot water line. That way you will have 4 gallons of hot water right there when you need it (4 gallons is usually alot more than you will use at one time in a kitchen). If you need more just let the water run a bit longer until the hot water comes from the water heater across the house.
If all of the fixtures are far away from the water heater then install a wall mounted unit, that heats the water as it passes through, alot closer to the fixtures. An electric one will not need a vent...just a 220 line.
FrankNBrew is offline   Reply With Quote
Page generated in 0.31309 seconds with 82 queries
