How/where to check fuel pressure on a 97 Ram - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 25th, 2007, 09:11 PM   #1
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Default How/where to check fuel pressure on a 97 Ram
Does anyone know where i can check the fuel pressure on a 97 Dodge ram? is there a fuel pressure check valve on the fuel rail like on a 99 TJ? What is the usual running pressure?
I'm the man in White.
Old July 25th, 2007, 09:47 PM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
I'm pretty sure there is, pressure should be around 70 psi approximately (I think).
Old July 25th, 2007, 10:13 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
the presure is more like 40-50 psi at the shrader valve on the rail. if you aren't seeing presure while cranking then your fuel pump relay could be fried. check that first.
Yetti
Page generated in 0.22436 seconds with 32 queries
