Rear bumper help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 20th, 2006, 07:18 PM   #1
Stonecutter
Death is my business
Stonecutter's Avatar
Default Rear bumper help
Has anyone out there made there own rear bumper/tire carrier. If so what did you use for the spindle/hub? Tried a a grade 5 1" bolt, to much flex and sag.
Thanks..
Stonecutter is offline   Reply With Quote
Old February 20th, 2006, 07:53 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if you go to a machine supply you should be able to find shaft & collars to make a pivot with, the collars have a allen screw and the bite in to the shaft so the shaft can be set to a given height. the shop I work for we use them to hold wheels on our test dollys, I have had them hold many thousands of pounds without failure. if you can,see if you can find tool steel shaft in the length you need...it won't flex.
Yetti
Old February 20th, 2006, 07:57 PM   #3
Sandals
Fucking Zen as Shit
Sandals's Avatar
Most good one's i've seen use a trailer spindle, hub and bearing assembly, definately the way to go.
Old February 20th, 2006, 08:34 PM   #4
Stonecutter
Where would you get a hub without the lugs and extra steel, you would only want something a tube.
Old February 20th, 2006, 11:24 PM   #5
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
www.rockstomper.com
JcrOffroad
Zoom Zoom!
Old February 21st, 2006, 09:15 AM   #6
Stonecutter
Originally Posted by monkeyevil
Thats what I'm looking for, thanks.
Page generated in 0.18656 seconds with 41 queries
