Trimming Fiberglass - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 20th, 2006, 05:52 PM   #1
Arnie897
y=mx+b
Arnie897's Avatar
Send a message via AIM to Arnie897
Default Trimming Fiberglass
I've seen trimmed up Jeep's....however they all have metal bodies. Is there anything to consider when cutting a fiberglass body to look like this?
Arnie897 is offline   Reply With Quote
Old February 20th, 2006, 06:16 PM   #2
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Don't breath the dust, wear gloves... use a fine toothed cutting utensile... make sure to support the peice well as you cut to prevent cracking...
JcrOffroad
Zoom Zoom!
Old February 20th, 2006, 08:21 PM   #3
amc78cj7
amc78cj7's Avatar
Fiberglass cuts easier than steel....
And ditto what the monkey said. Ever hear the song "Fred Bear" by Teddly? Fred Bear died from lung complications after spending a lifetime fabbing up bows from fiberglass. It's nasty stuff.
amc78cj7 is offline   Reply With Quote
Old February 20th, 2006, 08:43 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
couple of tips to cutting or working with fiberglass (even insulation)
Talcom poweder use it rub it all over any exposed skin. it plugs the poors to prevent the little fibers gettin ito your skin.
Breathing protection WEAR IT!!!! I have done enough damage to my lungs over the years and this stuff is bad for you, its like asbetos in your lungs the fibers burro in to the lung walls and never come out.
I have made many tools for working with glass and some are pretty trick. if you have to make up areas where you have huge gaps use masking to tape to fab up the space and the glass it in, the tape come right off after it sets.
Yetti
Old February 21st, 2006, 01:39 PM   #5
Arnie897
y=mx+b
Arnie897's Avatar
Thanks for the tips guys....I have the dust mask in hand already. So just a fine tooth sawzall blade or should I bust out the dremmel for this one? Also....I actually wasn't sure if the body could support that kind of trimming?
Old February 21st, 2006, 01:44 PM   #6
Yetti
Yetti's Avatar
if you think a panel is to week and might crack or rip, support it by clamping the panel in scrap wood and then cut all the layers at once, that or cut along the wood that supports the panel.
Yetti
Old February 21st, 2006, 03:04 PM   #7
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Glass bodies have strange reinforcements in them too. Watch for these areas and try not to cut them out. It's why most of them don't have opening tailgates...not enough strength to keep them from cracking.
Old February 23rd, 2006, 09:49 PM   #8
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
tp prevent delamination of the glass you will need to add a little bit of resin to the cut edges
Old February 24th, 2006, 07:41 AM   #9
LAWNMAN323
MOWUOVR
LAWNMAN323's Avatar
I'd invest in a respirator. I don't put a whole lot of faith in dust masks. My respirator is from 3M, can change the filters. Buy it once, buy it for life, your life!!
LAWNMAN323 is offline   Reply With Quote
Page generated in 0.35098 seconds with 50 queries
