YJ Parts Garage Sale (Michigan) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 21st, 2007, 10:06 PM   #1
jeepleader
jeepleader's Avatar
Default YJ Parts Garage Sale (Michigan)
Most parts came off a 92 YJ:
Warn removable winch cradle (never used but scuffed paint): $125
Older YJ Driver front seat (year-who knows-good condition): $10
Under dash AC Blower unit (worked the last time I used it): $25.00
YJ 4.0 HO used exhaust manifold (slightly cracked, where they all crack): $50 (I can weld the crack, if you want) - Roughly 30K miles
Fender Flares (typical faded): $20
Front Frame Cover (cracked on one side): FREE
OEM Under Hood Jack W/Tire Iron (a little rusty): $5
Fresh Air Box (cracked lid): $5
YJ front Drive Shaft: $10
YJ D30 Axle W/disconnect 3.07 gears? complete w/calipers, steering components & rotors: $65
YJ D35 Axle 3.07 gears? housing, drums, but w/out axle shafts: $35
94 YJ D30 Axle W/disconnect 4.10 gears, complete w/calipers & rotors: $85 (needs new pinion bearing)
TJ Front Drive Shaft (broken U-joint in CV part): $20
Non Jeep Related Parts:
(2) 1 Dia. X 100 150 PSI rated Fire Hose, brass fittings & plastic spray heads included: $40 for the pair or $25 each.
Prices are for pick-up only, additional required to ship.
See Pictures at: http://s89.photobucket.com/albums/k2...%20For%20Sale/
Email me or PM me for Pictures. Jeepleader@comcast.net
jeepleader is offline   Reply With Quote
Page generated in 0.22199 seconds with 26 queries
