LubeLocker Differential Gaskets - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 20th, 2007, 05:58 PM   #1
sodapop
Support the Sport!
sodapop's Avatar
Default LubeLocker Differential Gaskets
Not a ton of Tech to this post but thought it should go here anyway. In case you are wondering, I had to buy my gaskets and am getting nothing from LubeLocker.com so this is just for you info.
I'm sure some of you have heard of the LubeLocker diff seals. Well, I had the opportunity to install one of these today and I'm pretty impressed. Here's some pics of the install and some info about them.
Basic information.
- The LubeLocker Gasket installs dry, meaning with no RTV required
- It will not split or extrude during install
- It has several layers with an inner steel core coated with rubber and then it has some "elastomer beading" (red lines that run through the gasket) that also help seal.
- Though LubeLocker doesn't endorse the reuse of these gaskets, It's pretty obvious that they could be reused and on LubeLocker.com he mentions that. I'm guessing that he doesn't endorse reusing for liability reasons. Whatever the case, I think that the gasket could last several diff. changes
- you can get one for dana 30, 35, 44, 60; Ford 8.8, 9; Chrysler 8.25 and couple of tranny pans 999, 42RLE
- Manufacturer Suggested retail is $16.95 from LubeLocker.com and it's about $6 - $9 more for shipping. Every web site I found them on has them within $1 of MSRP. Shipping doesn't seem to change if you order one or 2. I also have one for my front 44 but am waiting until my locker arrives before I install it.
Install
I would say that you should be able to complete this install in 30 minutes or less with simple hand tools.
Drain your old fluid. I had to use a prybar and a hammer to get my cover off. The LubeLocker will put a stop to that.
Clean all the old RTV off both the cover and the diff housing. I find that using a wire wheel on an angle grinder of die grinder works well. A gasket scraper will work too for those of you who are power tool challenged. Finish the cleaning process with Brake cleaner to make sure there is no residue in the cover or in you diff.
The Lube Locker comes in a sealed plastic bag with a piece of cardboard in it to keep it from getting easily bent.
Side view of the gasket. it's tough to see but the core is steel with a rubber coating on both sides as well as "elastomer beading" on both sides as well.
The fit and finish on these things are perfect. The bolt holes line up perfectly and the gasket fits completely within the edges of the housing. I was a little worried that it would stick out like most gaskets do and get torn, bent, or in some other way damaged. No worries here though.
The last step is to install the gasket and cover. Lube locker has torque specs to use and also gives you a pattern on the package to follow. it's a 2 step process. The first step is to torque to 15ft/lbs and then the second is to torque to 35ft/lbs. In all seriousness though, if you don't have a torque wrench, just put it on following the torque pattern and you should be good.
After the cover is torqued down, fill your differential with the appropriate amount of lube, reinstall your drain plug and you're done.
I didn't notice any leaks after install, I waited for several hours and checked again and there still wasn't any leaks. It's part in my garage now and I'll check again and update in a day or so.
Here's a pic with the diff cover on from underneath. The gasket fits perfect, even the notches on the bottom of my 8.8 were stamped into the gasket.
I'm very pleased with how well the LubeLocker fit and how well it's working so far. I think it will be nice to not mess with RTV if I ever have to pull the cover on the trail. it'll make the whole process quicker and easier.
Old July 20th, 2007, 08:49 PM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Where did you get it? And cost?
Old July 21st, 2007, 09:59 AM   #3
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
I tried these and only the front didn't leak. Seemed like a decent product but didn't work for me. RTV is cheap and works better for me.
GNJEEPN is offline   Reply With Quote
Old July 21st, 2007, 10:44 AM   #4
rustcharger
dubs ain't sh*t
rustcharger's Avatar
So you paid 33.90 + shipping for a couple diff cover gaskets?
Can I get a ride on your yacht?
rustcharger is offline   Reply With Quote
Old July 21st, 2007, 12:48 PM   #5
sodapop
Support the Sport!
sodapop's Avatar
You can buy them from several on-line dealers. I got mine from LubeLocker directly. Cheapest online price I found was $15.95, I think that was Mesa 4x4 or something like that.
So far, I've got no leaks at all. RTV is cheap but the last time I needed it on the trail, it had hardened and was no good. Your's is the first I've heard of with problems. Is your cover in good shape? I hear ya about RTV being cheap, normally, I try to save all my pennies, but decided differently this time....
Seriously... a yacht. Where I come from a yacht costs more than $33. I know that Clio isn't a fancy schmancy town, maybe they're cheaper there?
I'm not sure what you've got in your rig but I've got several grand wrapped up into my axles and I'm okay with spending a little on gaskets if it will make things easier and keep the fluid in. If it saves me 15 minutes of cleaning on the trail, it'll be worth EVERY penny. Hell if it saves me 5 minutes or even if I don't touch my diff until the next service, I'm still good with that and think it's a good investment for me.
Hey and next time you have a smart ass comment, why don't you keep it to the pub instead of here in the tech posts, even if they aren't very technical.
Old July 21st, 2007, 03:26 PM   #6
rustcharger
dubs ain't sh*t
jeez didn't mean to hurt your feelings about your new gaskets most folks on here have a better sense of humor than you.
Old July 21st, 2007, 07:37 PM   #7
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
OX lockers solid cover and yes it's strait. I keep a fresh tube of RTV in my tool box. Save the original cap and clean out the addapter if you really want to be cheap after using it. Otherwise throw it out after use and get another tube.:miff:
Old July 22nd, 2007, 10:41 AM   #8
greenmeanie
greenmeanie's Avatar
nice diff cover; i need one for my 8.8. thanks for the gasket info, even if people are being a bit turse about it.
greenmeanie is offline   Reply With Quote
Old July 22nd, 2007, 10:50 AM   #9
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
I've been using them for a few years with no problems. I've reused them for at least 6 lube changes with no leaks.
One Arm Steve is offline   Reply With Quote
Old July 22nd, 2007, 01:54 PM   #10
sodapop
Support the Sport!
sodapop's Avatar
Rockcrusher is no longer around, they were bought by Solid. Solid still sells the cover though only it says solid on it. It's a beefy cover. My only complaint is that the send the cover with grade hex head 8 bolts and they don't clearance the cover enough for a socket to fit on it. It would work a lot better better with socket head/Allen style bolts
That's good to know. I figured on getting somewhere around 4 uses out of them but wasn't sure. Rockcrawler.com has a review of them and they got a couple uses out of them but then had the elastomer bead spread alittle. Still looks like it would seal but they replaced it anyway.
Old July 23rd, 2007, 11:17 PM   #11
scorpio_vette
scorpio_vette's Avatar
Send a message via MSN to scorpio_vette Send a message via Yahoo to scorpio_vette
i've been looking at those for a while because i HATE RTV with a passion. but i don't see paying that much +shipping when i can get felpro gaskets at any parts store and the cover comes off by hand and requires nearly no cleaning at all. only one 1 or 2 rare occasions have i ever had to remove a piece of gasket. but it's not like trying to remove that rtv crap.
now if somebody locally starts carrying the lubelocker gasket, then i might get some. till then i'll stick with felpro gaskets for $3 and keep throwing away the rtv anyways.
just my opinion.
scorpio_vette is offline   Reply With Quote
Page generated in 0.38858 seconds with 56 queries
