Blown Head gasket - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 20th, 2006, 02:32 PM   #1
Icebreaker88
Icebreaker88's Avatar
Default Blown Head gasket
Looks like my deal of a jeep came with a blown head gasket as a bonus.
Do I need to replace the head bolts when replacing the head gasket.
And anything else I should look for while I am doing this.
Or any good tips while doing this
I am not new to wrenching just never worked on a 4.0 jeep motor before.
Oh yeah and Ed I own a Jeep now so I am sure I will be working on it all the time:miff:
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old February 20th, 2006, 03:16 PM   #2
What I've always *heard* is to never reuse head bolts..
But I'm cheap..
I think the hardest part of that job is going to be getting the manifolds off. There's a lott bolts and not much clearance in the XJ's engine bay.
If you have them apart, it might be a good time to inspect the exhaust manifold really good, as they are prone to cracking.
Old February 20th, 2006, 04:46 PM   #3
shawn
Resident HVAC/R Jambi
shawn's Avatar
I had my 258 apart about 6 times, and re-used the head bolts. One of those times, was from a blown head gasket.
Old February 20th, 2006, 04:53 PM   #4
Icebreaker88
I did notice a little bit of an exhaust manifold leak. Maybe just gasket or could be cracked header.
If the heade is bad What do you guys think about this?
http://cgi.ebay.com/ebaymotors/91-99...38938381QQrdZ1
Old February 20th, 2006, 09:54 PM   #5
Icebreaker88
Well I have it all pulled apart and the front 2 cylinders, intake valves were pretty white compared to the others.
Also looks like the header is fine, cant see any cracks or any place it was leaking.
Well of to 24hr murrays for the gaskets and put it back together.
Old February 20th, 2006, 10:10 PM   #6
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
did you put a straight edge on the head to make sure it wasn't warped? secondly if you removed the manifolds you can take them to a machine shop and have them clearence cut or sanded to make them flat again. then they will seal much better because their seasoned.
as for bad head bolts, look at the ones you took out, if any have stretch marks or feel wierd when tightening like the had some "give" to them toss them and and get new. I have broken them while torquing them in before.
Yetti
Old February 20th, 2006, 10:11 PM   #7
Yetti
Yetti's Avatar
by the way don't forget to get the head "magnafluxed" to check for cracks. look real carfully between the valves where they seat.
Yetti
Old February 20th, 2006, 10:27 PM   #8
Pre4runner
Bike Dude
Pre4runner's Avatar
*Just a note*
if the head bolts are torque to yield, Replace them! one way of knowing is it will give you a torque then a torque angle... otherwise reusing them should be fine... And i don't think they are torque to yield...
*just a note*
Old February 21st, 2006, 09:48 AM   #9
SS
Bananarama!
SS's Avatar
That's just a Dorman factory replacement manifold... that is in no way a racing header. In fact that's false advertising....
Anyway..
If you're going to upgrade everyone has their opinion of what's the best but I always heard good things about Borla and Thorley.
-Jer
Old February 21st, 2006, 10:13 AM   #10
Bones
Bones's Avatar
a lot of factory head bolts can be used twice
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 21st, 2006, 10:39 AM   #11
I think I have a Mopar service manual at home, I'll check that. Every service manual I've seen for whatever I'm driving always says to replace the head bolts, but most people reuse them.
Old February 21st, 2006, 10:55 AM   #12
dune coon
do work
dune coon's Avatar
Default wtf?
Anyway..
that looks like a total piece of shit.
i dont think i'd trust someone selling me a header if they can't spell "Qualiyt"
dune coon is offline   Reply With Quote
Old February 21st, 2006, 11:29 AM   #13
Like was said, thats a replacement manifold, you can get them I think at autozone or the like. The expansion sections are there to prevent cracking.
Old February 21st, 2006, 09:32 PM   #14
Pre4runner
Bike Dude
Pre4runner's Avatar
True too... just tossed that other bit out there. Personally i re-used the headbolts on my 22re 3 times now, just chased the threads to be safe
Old February 22nd, 2006, 12:27 AM   #15
Icebreaker88
I cleaned the head up and visually inspected it , looked like no cracks.
As for the bolts they looked good also.
I reassembled everything and it runs fine and does not pressurize the coolant system anymore so hopefully problem fixed. also got rid of my exhaust manifold leak
Thanks for all the input
Old February 22nd, 2006, 11:15 AM   #16
h8pvmnt
Swamp Stomper
h8pvmnt's Avatar
You didn't ask me my opinion before you bought it, so don't try to blame me now.
Jeep> <Mike
h8pvmnt is offline   Reply With Quote
Old February 22nd, 2006, 06:26 PM   #17
Icebreaker88
Oh by the way Ed that track bar made a world of diffrence.
Thanks
Old February 22nd, 2006, 09:49 PM   #18
Thanks
Did you have the Death Wobble?
I have a crappy rubicon express bar, with a Heim joint. Even 1/32nd of play in that heim joist caused massive deathwobble.
Old February 22nd, 2006, 10:14 PM   #19
Icebreaker88
It had a little death wobble. It had some type of aftermarket track bar I was told because the frame end of it was threaded and replacable, but it was wasted.
Page generated in 1.44555 seconds with 80 queries
